Zum Hauptinhalt wechseln
HP 15-dw0037wm Battery Replacement
Was du brauchst
  1. HP 15-dw0037wm Battery Replacement, Lower Case: Schritt 1, Bild 1 von 2 HP 15-dw0037wm Battery Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
    • Set the laptop down with the lower case facing up.
    • Lift a corner of the lower silicone foot and peel it completely off.
    • Repeat for the upper silicone foot.
  2. HP 15-dw0037wm Battery Replacement: Schritt 2, Bild 1 von 2 HP 15-dw0037wm Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the five 8 mm screws.
    • Remove the two 5 mm Phillips screws.
  3. HP 15-dw0037wm Battery Replacement: Schritt 3, Bild 1 von 3 HP 15-dw0037wm Battery Replacement: Schritt 3, Bild 2 von 3 HP 15-dw0037wm Battery Replacement: Schritt 3, Bild 3 von 3
    • Insert an opening pick into the gap between the lower case and chassis.
    • Starting from a corner is recommended.
    • Slide the pick around the entire perimeter of the device until the lower case fully releases.
    • Remove the lower case.
  4. HP 15-dw0037wm Battery Replacement, Battery: Schritt 4, Bild 1 von 2 HP 15-dw0037wm Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use a Phillips screwdriver to remove the the four 4 mm screws that secure the battery.
  5. HP 15-dw0037wm Battery Replacement: Schritt 5, Bild 1 von 3 HP 15-dw0037wm Battery Replacement: Schritt 5, Bild 2 von 3 HP 15-dw0037wm Battery Replacement: Schritt 5, Bild 3 von 3
    • Lift the battery out slowly to disconnect it from the socket that connects it to the motherboard.
    • Removing the battery quickly can damage the socket that the motherboard is connected to.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Emily Davila
651 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 37
Insgesamt: 152
