Zum Hauptinhalt wechseln
HP 2000 - 2D22DX RAM Replacement
Was du brauchst
  1. HP 2000 - 2D22DX RAM Replacement, Battery: Schritt 1, Bild 1 von 2 HP 2000 - 2D22DX RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
    Frag FixBot
    Kommentar hinzufügen
  2. HP 2000 - 2D22DX RAM Replacement: Schritt 2, Bild 1 von 2 HP 2000 - 2D22DX RAM Replacement: Schritt 2, Bild 2 von 2
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
    Frag FixBot
  3. HP 2000 - 2D22DX RAM Replacement, RAM: Schritt 3, Bild 1 von 2 HP 2000 - 2D22DX RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • After battery removal, the RAM compartment cover is exposed.
    • Locate the Phillips head screw seen in the second picture. It secures the RAM compartment to the plastic chassis.
    • Loosen the screw that is securing the RAM compartment with a Phillips #00 screwdriver.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
    Frag FixBot
  4. HP 2000 - 2D22DX RAM Replacement: Schritt 4, Bild 1 von 2 HP 2000 - 2D22DX RAM Replacement: Schritt 4, Bild 2 von 2
    • Once the screw is sufficiently loosened, gently unclip the RAM compartment cover from its slots in the plastic chassis.
    • Pull the compartment door out and away from the chassis, exposing the black film covering the RAM module.
    Frag FixBot
  5. HP 2000 - 2D22DX RAM Replacement: Schritt 5, Bild 1 von 3 HP 2000 - 2D22DX RAM Replacement: Schritt 5, Bild 2 von 3 HP 2000 - 2D22DX RAM Replacement: Schritt 5, Bild 3 von 3
    • Move the black plastic film to the side to locate the RAM slots.
    • Locate the metal clips holding the RAM card in place.
    • Using your fingers, push the metal clips out and away from the RAM module until the RAM module pops up at a 45 degree angle.
    Frag FixBot
  6. HP 2000 - 2D22DX RAM Replacement: Schritt 6, Bild 1 von 1
    • Hold the black plastic film away from the RAM slots. Grasp the edge of the RAM card and slide it out at a 45 degree angle.
    • Maintain the 45 degree angle of the RAM card until all pins are disengaged. Failure to do so may result in pin breakage.
    Frag FixBot
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 3-40, Maness Spring 2014 Mitglied von Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 22
Letzte 30 Tage: 62
Insgesamt: 4,338
