Zum Hauptinhalt wechseln
HP Chromebook 11 G8 EE Battery Replacement
Was du brauchst
  1. HP Chromebook 11 G8 EE Battery Replacement, Keyboard & Touchpad Assembly: Schritt 1, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Battery Replacement: Schritt 2, Bild 1 von 2 HP Chromebook 11 G8 EE Battery Replacement: Schritt 2, Bild 2 von 2
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Battery Replacement: Schritt 3, Bild 1 von 3 HP Chromebook 11 G8 EE Battery Replacement: Schritt 3, Bild 2 von 3 HP Chromebook 11 G8 EE Battery Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Do not puncture or damage any parts of the battery.
    • Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
    • The speakers are removed in these images, but they don't need to be to replace the battery.
  5. HP Chromebook 11 G8 EE Battery Replacement: Schritt 5, Bild 1 von 3 HP Chromebook 11 G8 EE Battery Replacement: Schritt 5, Bild 2 von 3 HP Chromebook 11 G8 EE Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove the four 3.5 mm Phillips #1 screws securing the battery.
    • If you've already removed the speakers, you'll only need to remove the two screws on the top of the battery, near the motherboard.
  6. HP Chromebook 11 G8 EE Battery Replacement: Schritt 6, Bild 1 von 2 HP Chromebook 11 G8 EE Battery Replacement: Schritt 6, Bild 2 von 2
    • Carefully lift the battery up and out.
Abschluss
Julia Latura
328 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Mitglied von UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
5 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 23
Letzte 30 Tage: 77
Insgesamt: 696
