Zum Hauptinhalt wechseln
HP Chromebook 14-Q010DX Fan Replacement
Was du brauchst
  1. HP Chromebook 14-Q010DX Fan Replacement, Keyboard and Touchpad: Schritt 1, Bild 1 von 2 HP Chromebook 14-Q010DX Fan Replacement, Keyboard and Touchpad: Schritt 1, Bild 2 von 2
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Chromebook 14-Q010DX Fan Replacement: Schritt 2, Bild 1 von 3 HP Chromebook 14-Q010DX Fan Replacement: Schritt 2, Bild 2 von 3 HP Chromebook 14-Q010DX Fan Replacement: Schritt 2, Bild 3 von 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    Frag FixBot
  3. HP Chromebook 14-Q010DX Fan Replacement: Schritt 3, Bild 1 von 3 HP Chromebook 14-Q010DX Fan Replacement: Schritt 3, Bild 2 von 3 HP Chromebook 14-Q010DX Fan Replacement: Schritt 3, Bild 3 von 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    Frag FixBot
  4. HP Chromebook 14-Q010DX Fan Replacement: Schritt 4, Bild 1 von 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    Frag FixBot
  5. HP Chromebook 14-Q010DX Fan Replacement: Schritt 5, Bild 1 von 1
    • Set aside the detached keyboard.
    Frag FixBot
  6. HP Chromebook 14-Q010DX Fan Replacement, Fan replacement for a HP Chromebook: Schritt 6, Bild 1 von 3 HP Chromebook 14-Q010DX Fan Replacement, Fan replacement for a HP Chromebook: Schritt 6, Bild 2 von 3 HP Chromebook 14-Q010DX Fan Replacement, Fan replacement for a HP Chromebook: Schritt 6, Bild 3 von 3
    • Remove the 3 screws around the fan.
    • Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
    Frag FixBot
  7. HP Chromebook 14-Q010DX Fan Replacement: Schritt 7, Bild 1 von 1
    • Once the cable connecting the fan to the motherboard is revomed gently remove fan with hands.
    Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 17-2, Watkins Winter 2015 Mitglied von USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Mitglieder
8 Anleitungen geschrieben
1 Kommentar zur Anleitung
Add Comment:
Akshit Fnu - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 41
Insgesamt: 4,264
