Zum Hauptinhalt wechseln
HP Compaq 515 Wireless Card Replacement
Was du brauchst
  1. HP Compaq 515 Wireless Card Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Compaq 515 Wireless Card Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the two screws with a PH00 bit. This releases the hard drive.
    • The screws are held in place, so there is no need to worry about losing them
    Frag FixBot
  3. HP Compaq 515 Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
    Frag FixBot
  4. HP Compaq 515 Wireless Card Replacement, Wireless Card: Schritt 4, Bild 1 von 1
    • The wireless card is located on the bottom of the laptop, however the hard drive case must be removed in order to access the wireless card.
    Frag FixBot
  5. HP Compaq 515 Wireless Card Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the two screws holding the hard drive in place, using a PH00 bit.
    Frag FixBot
  6. HP Compaq 515 Wireless Card Replacement: Schritt 6, Bild 1 von 2 HP Compaq 515 Wireless Card Replacement: Schritt 6, Bild 2 von 2
    • Slide the wireless card backing towards you to remove it from the laptop.
    Frag FixBot
  7. HP Compaq 515 Wireless Card Replacement: Schritt 7, Bild 1 von 1
    • Gently remove the black and white wires that are connected to the wireless card.
    • The wires are held firmly in place, so it may take some force to remove them. Be cautious when doing so as the wires may tear or fray
    Frag FixBot
  8. HP Compaq 515 Wireless Card Replacement: Schritt 8, Bild 1 von 1
    • Remove the two .4 cm screws with a PH00 bit.
    Frag FixBot
Abschluss
Aleks B
337 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S4-G1, Covino Spring 2018 Mitglied von UMass Dartmouth, Team S4-G1, Covino Spring 2018
UMASSD-COVINO-S18S4G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 536
