Zum Hauptinhalt wechseln
HP Mini 311 Keyboard Replacement
Was du brauchst
  1. HP Mini 311 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 HP Mini 311 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 HP Mini 311 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Mini 311 Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Mini 311 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery away from the device to remove.
    Frag FixBot
  3. HP Mini 311 Keyboard Replacement, Memory Shield: Schritt 3, Bild 1 von 1
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
    Frag FixBot
  4. HP Mini 311 Keyboard Replacement: Schritt 4, Bild 1 von 2 HP Mini 311 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Lift the memory shield up and remove from the laptop.
    Frag FixBot
  5. HP Mini 311 Keyboard Replacement, Hard Drive: Schritt 5, Bild 1 von 3 HP Mini 311 Keyboard Replacement, Hard Drive: Schritt 5, Bild 2 von 3 HP Mini 311 Keyboard Replacement, Hard Drive: Schritt 5, Bild 3 von 3
    • Grab the left black, plastic tab and carefully pull upward.
    • Be sure to pull carefully. Pulling too forcefully may damage the tab.
    Frag FixBot
  6. HP Mini 311 Keyboard Replacement: Schritt 6, Bild 1 von 3 HP Mini 311 Keyboard Replacement: Schritt 6, Bild 2 von 3 HP Mini 311 Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Grab a hold of the wire connecting the hard drive and the device.
    • Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
    Frag FixBot
  7. HP Mini 311 Keyboard Replacement, Keyboard: Schritt 7, Bild 1 von 1
    • Unscrew the four Phillip 00 5.6 mm screws located around the wireless card and RAM.
    Frag FixBot
  8. HP Mini 311 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Open the laptop so that the screen and front of the keyboard are both facing the ground.
    • Push on the opening on the back side of the device until the keyboard partially pops out.
    • This opening is located where the original hard drive was set.
    Frag FixBot
  9. HP Mini 311 Keyboard Replacement: Schritt 9, Bild 1 von 3 HP Mini 311 Keyboard Replacement: Schritt 9, Bild 2 von 3 HP Mini 311 Keyboard Replacement: Schritt 9, Bild 3 von 3
    • Flip the device around and orient it so that the screen and keyboard are facing you.
    • Starting at the right side, work your way towards the left end and remove the keyboard by unhinging the latches attaching it to the base of the device.
    • The right side of the keyboard should be unattached.
    • Be gentle and patient. You don't want to pull the entire keyboard at once, but rather pull by sections.
    Frag FixBot
  10. HP Mini 311 Keyboard Replacement: Schritt 10, Bild 1 von 3 HP Mini 311 Keyboard Replacement: Schritt 10, Bild 2 von 3 HP Mini 311 Keyboard Replacement: Schritt 10, Bild 3 von 3
    • Carefully pull the ribbon cable connecting the keyboard and the laptop to remove from the device.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 20-4, Maness Winter 2013 Mitglied von Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 25
Insgesamt: 2,971
