Zum Hauptinhalt wechseln
HP Notebook 15-ba018ds RAM Replacement
Was du brauchst
  1. HP Notebook 15-ba018ds RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Notebook 15-ba018ds RAM Replacement: Schritt 2, Bild 1 von 3 HP Notebook 15-ba018ds RAM Replacement: Schritt 2, Bild 2 von 3 HP Notebook 15-ba018ds RAM Replacement: Schritt 2, Bild 3 von 3
    • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
    • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
    Frag FixBot
  3. HP Notebook 15-ba018ds RAM Replacement, RAM: Schritt 3, Bild 1 von 2 HP Notebook 15-ba018ds RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • Unscrew the 8 screws on the back cover.
    • There are also two screws in the battery area that you unscrew.
    Frag FixBot
  4. HP Notebook 15-ba018ds RAM Replacement: Schritt 4, Bild 1 von 1
    • Use an opening tool and wedge it under the edge and go around the whole laptop to help remove the back cover.
    • On the side of the laptop, you can see where it can be separated into two parts.
    Frag FixBot
  5. HP Notebook 15-ba018ds RAM Replacement: Schritt 5, Bild 1 von 3 HP Notebook 15-ba018ds RAM Replacement: Schritt 5, Bild 2 von 3 HP Notebook 15-ba018ds RAM Replacement: Schritt 5, Bild 3 von 3
    • This laptop has one RAM.
    • Gently pull out the RAM from the socket.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 30
Insgesamt: 1,611
