Zum Hauptinhalt wechseln
HP Pavilion 15-ab243cl CMOS Battery Replacement
Was du brauchst
  1. HP Pavilion 15-ab243cl CMOS Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion 15-ab243cl CMOS Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the battery lock tab toward the center of the battery to the unlock position.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 2, Bild 1 von 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 2, Bild 2 von 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 2, Bild 3 von 3
    • Slide the battery release switch to the right until the battery pops out.
    Frag FixBot
  3. HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 3, Bild 2 von 2
    • Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot.
    Frag FixBot
  4. HP Pavilion 15-ab243cl CMOS Battery Replacement, Laptop Case: Schritt 4, Bild 1 von 3 HP Pavilion 15-ab243cl CMOS Battery Replacement, Laptop Case: Schritt 4, Bild 2 von 3 HP Pavilion 15-ab243cl CMOS Battery Replacement, Laptop Case: Schritt 4, Bild 3 von 3
    • With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
    Frag FixBot
  5. HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove all 16 of the 3.5 mm screws with a PH1 screwdriver and pry/slide the CD drive out of laptop.
    Frag FixBot
  6. HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 6, Bild 1 von 2 HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 6, Bild 2 von 2
    • With the CD drive removed, unscrew the two 2mm silver screws with a PH00.
    • These can strip easily, so take your time removing.
    Frag FixBot
  7. HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 7, Bild 1 von 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 7, Bild 2 von 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 7, Bild 3 von 3
    • Using a plastic opening tool, begin to pry edge of case away from the laptop. Work around the edges until all sides, except back, are open.
    Frag FixBot
  8. HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 8, Bild 1 von 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 8, Bild 2 von 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 8, Bild 3 von 3
    • On the back side of the laptop, where the battery is, there are 12 black plastic clips. Use a plastic opening tool and pry all of these clips, unlatching them from the case.
    • Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case.
    Frag FixBot
  9. HP Pavilion 15-ab243cl CMOS Battery Replacement, CMOS Battery: Schritt 9, Bild 1 von 2 HP Pavilion 15-ab243cl CMOS Battery Replacement, CMOS Battery: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use long nose tweezers to reach under battery and lift up.
    Frag FixBot
  10. HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 10, Bild 1 von 2 HP Pavilion 15-ab243cl CMOS Battery Replacement: Schritt 10, Bild 2 von 2
    • Lift up until battery pops out, remove battery
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S6-G3, Eyestone Spring 2018 Mitglied von USF Tampa, Team S6-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S6G3
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 84
Insgesamt: 2,120
