Zum Hauptinhalt wechseln
HP Pavilion 15-cc123cl Hard Drive Replacement
Was du brauchst
  1. HP Pavilion 15-cc123cl Hard Drive Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Make sure to power off the laptop before proceeding with the guide.
    • Turn the laptop over so the back is facing up. Use a Phillips #0 screwdriver to remove the 11 screws from the bottom cover. Rotate the screws counter-clockwise.
    • Eight 5mm screws.
    • Three 10mm screws.
  2. HP Pavilion 15-cc123cl Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Pavilion 15-cc123cl Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Pavilion 15-cc123cl Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Gently remove the CD-ROM drive by using a plastic opening tool and sliding it out of the laptop housing.
    • Using the opening tool, gently pry open the back panel of the laptop. Slowly work around the edge of the laptop with gentle pressure.
    • Remove the back cover from the laptop.
  3. HP Pavilion 15-cc123cl Hard Drive Replacement, Battery: Schritt 3, Bild 1 von 3 HP Pavilion 15-cc123cl Hard Drive Replacement, Battery: Schritt 3, Bild 2 von 3 HP Pavilion 15-cc123cl Hard Drive Replacement, Battery: Schritt 3, Bild 3 von 3
    • Remove the six 5mm screws securing the battery using the Phillips #0 screwdriver.
    • Gently disconnect the battery from the motherboard with a plastic opening tool and remove it from the device.
    • If you're installing a new battery, you should calibrate it after installation.
    • Charge it to 100% and continue to charge it for an additional two hours. Next, unplug the charger and use the laptop normally to completely drain the battery. Wait at least five hours and recharge the battery to 100%.
  4. HP Pavilion 15-cc123cl Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 HP Pavilion 15-cc123cl Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Use the iFixit opening tool to pry out the hard drive.
    • Do not completely remove the hard drive yet since it is still connected to the ribbon.
  5. HP Pavilion 15-cc123cl Hard Drive Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 15-cc123cl Hard Drive Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 15-cc123cl Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the ribbon cable connecting the hard drive to the motherboard.
    • Remove the hard drive from the device.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 56
Insgesamt: 3,666
