Einleitung
This guide will help you replace the battery of the HP Pavilion 15-n210dx if the battery loses its ability to hold onto charge or enough charge to do daily tasks on the computer.
A battery has a certain amount of charging cycles. After each charge cycle, the ability for the battery to hold onto charge decreases slightly, eventually leading to a dead battery.
If the battery is swollen or deformed, discontinue the use of the computer until you can install a new one. A swollen battery is not a safety issue according to HP.
The laptop should be shutdown and unplugged before you start the steps.
No tools are necessary for this guide.
Push the pins towards each other using your thumbs. The battery will pop out a little bit. Remove it using your hand.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
