Zum Hauptinhalt wechseln
HP Pavilion x360 14-dw Back Cover Replacement
Was du brauchst
  1. HP Pavilion x360 14-dw Back Cover Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 1 von 1
    • Fully shut down your laptop and unplug all cables.
  2. HP Pavilion x360 14-dw Back Cover Replacement, Flip your laptop over: Schritt 2, Bild 1 von 1
    • Flip your laptop over so the rubber feet are facing up.
  3. HP Pavilion x360 14-dw Back Cover Replacement, Expose the back cover screws: Schritt 3, Bild 1 von 3 HP Pavilion x360 14-dw Back Cover Replacement, Expose the back cover screws: Schritt 3, Bild 2 von 3 HP Pavilion x360 14-dw Back Cover Replacement, Expose the back cover screws: Schritt 3, Bild 3 von 3
    • The ends of the rubber feet cover four back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be lifted up as one piece.
    • Peel up the end of the foot with your fingers just until the hidden screw underneath is exposed—you don't need to fully remove the foot.
  4. HP Pavilion x360 14-dw Back Cover Replacement: Schritt 4, Bild 1 von 3 HP Pavilion x360 14-dw Back Cover Replacement: Schritt 4, Bild 2 von 3 HP Pavilion x360 14-dw Back Cover Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Tesa 61395 Tape
    $5.99
    • Peel up the other ends of the feet to expose the three remaining screws.
    • During reassembly:
    • Press down firmly on the ends of the feet to secure them into their recesses.
    • If the foot adhesive doesn't remain tacky enough to readhere, you can use double-sided tape such as Tesa Tape.
  5. HP Pavilion x360 14-dw Back Cover Replacement, Unfasten the back cover: Schritt 5, Bild 1 von 2 HP Pavilion x360 14-dw Back Cover Replacement, Unfasten the back cover: Schritt 5, Bild 2 von 2
    • Use a Phillips screwdriver to remove the five screws securing the back cover:
    • Four larger 6.7 mm-long black screws
    • One smaller 2.9 mm-long silver screw
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
  6. HP Pavilion x360 14-dw Back Cover Replacement, Release the clips: Schritt 6, Bild 1 von 2 HP Pavilion x360 14-dw Back Cover Replacement, Release the clips: Schritt 6, Bild 2 von 2
    • Tight plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
    • Insert the flat side of an opening pick into the seam between the top right corner of the back cover and the frame.
    • Pry up to release the clips securing the back cover.
  7. HP Pavilion x360 14-dw Back Cover Replacement: Schritt 7, Bild 1 von 3 HP Pavilion x360 14-dw Back Cover Replacement: Schritt 7, Bild 2 von 3 HP Pavilion x360 14-dw Back Cover Replacement: Schritt 7, Bild 3 von 3
    • Insert the flat end of a spudger into the gap you just created.
    • Slide the spudger down to the bottom right corner to release the clips on the right edge.
  8. HP Pavilion x360 14-dw Back Cover Replacement: Schritt 8, Bild 1 von 3 HP Pavilion x360 14-dw Back Cover Replacement: Schritt 8, Bild 2 von 3 HP Pavilion x360 14-dw Back Cover Replacement: Schritt 8, Bild 3 von 3
    • Insert the flat end of a spudger between the bottom right corner of the back cover and frame.
    • Slide the spudger to the bottom left corner to release the clips.
  9. HP Pavilion x360 14-dw Back Cover Replacement: Schritt 9, Bild 1 von 3 HP Pavilion x360 14-dw Back Cover Replacement: Schritt 9, Bild 2 von 3 HP Pavilion x360 14-dw Back Cover Replacement: Schritt 9, Bild 3 von 3
    • Insert the flat end of a spudger between the bottom left corner of the back cover and frame.
    • Slide the spudger up to the top left corner to release the clips on the left edge.
  10. HP Pavilion x360 14-dw Back Cover Replacement: Schritt 10, Bild 1 von 2 HP Pavilion x360 14-dw Back Cover Replacement: Schritt 10, Bild 2 von 2
    • Insert the flat side of an opening pick into the seam between the top edge of the back cover and frame, just to the right of the left hinge.
    • Pry up to release the clips.
  11. HP Pavilion x360 14-dw Back Cover Replacement: Schritt 11, Bild 1 von 3 HP Pavilion x360 14-dw Back Cover Replacement: Schritt 11, Bild 2 von 3 HP Pavilion x360 14-dw Back Cover Replacement: Schritt 11, Bild 3 von 3
    • Slide the spudger towards the right hinge to release the remaining clips.
  12. HP Pavilion x360 14-dw Back Cover Replacement, Remove the back cover: Schritt 12, Bild 1 von 3 HP Pavilion x360 14-dw Back Cover Replacement, Remove the back cover: Schritt 12, Bild 2 von 3 HP Pavilion x360 14-dw Back Cover Replacement, Remove the back cover: Schritt 12, Bild 3 von 3
    • Remove the back cover.
    • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all the clips.
Abschluss
Spencer Day
95.592 Reputation
662 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
119 Mitglieder
19.523 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 140
Insgesamt: 2,358
