Zum Hauptinhalt wechseln
HP ProBook 4320t RAM Replacement Guide
Was du brauchst
  1. HP ProBook 4320t RAM Replacement Guide, Battery Removal: Schritt 1, Bild 1 von 2 HP ProBook 4320t RAM Replacement Guide, Battery Removal: Schritt 1, Bild 2 von 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
    Frag FixBot
    Kommentar hinzufügen
  2. HP ProBook 4320t RAM Replacement Guide, Screws: Schritt 2, Bild 1 von 2 HP ProBook 4320t RAM Replacement Guide, Screws: Schritt 2, Bild 2 von 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
    Frag FixBot
  3. HP ProBook 4320t RAM Replacement Guide, Flip: Schritt 3, Bild 1 von 1
    • Flip laptop over and open it.
    Frag FixBot
  4. HP ProBook 4320t RAM Replacement Guide, Push N Lift: Schritt 4, Bild 1 von 1
    • Slightly push up while lifting up on the power button panel to release the panel.
    Frag FixBot
  5. HP ProBook 4320t RAM Replacement Guide, Unscrewing: Schritt 5, Bild 1 von 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
    Frag FixBot
  6. HP ProBook 4320t RAM Replacement Guide, Careful Now: Schritt 6, Bild 1 von 2 HP ProBook 4320t RAM Replacement Guide, Careful Now: Schritt 6, Bild 2 von 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
    Frag FixBot
  7. HP ProBook 4320t RAM Replacement Guide, Disconnect Wire: Schritt 7, Bild 1 von 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
    Frag FixBot
  8. HP ProBook 4320t RAM Replacement Guide, RAM: Schritt 8, Bild 1 von 1
    • Press the two prongs outward, and the RAM card will come out of PCI Express connector.
    Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 9-5, Blackwell Fall 2014 Mitglied von USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 18
Insgesamt: 1,498
