Zum Hauptinhalt wechseln
HP Spectre x360 13-4103dx Battery Replacement
Was du brauchst
  1. HP Spectre x360 13-4103dx Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn off your laptop before you start.
    • Flip your laptop so the bottom is facing upwards.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Spectre x360 13-4103dx Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #0 to remove the screws that hold the back panel down.
    Frag FixBot
  3. HP Spectre x360 13-4103dx Battery Replacement: Schritt 3, Bild 1 von 1
    • Use an opening tool to remove the back panel.
    • Be careful when applying force to the panel so the components and the panel are not damaged.
    • Try to start at a corner or a place with the most room to slide under the panel.
    Frag FixBot
  4. HP Spectre x360 13-4103dx Battery Replacement, Battery: Schritt 4, Bild 1 von 2 HP Spectre x360 13-4103dx Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the four screws from the battery using a Phillips #0 screwdriver.
    Frag FixBot
  5. HP Spectre x360 13-4103dx Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery from the computer.
    Frag FixBot
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
UMass Dartmouth, Team 3-6, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 35
Insgesamt: 1,063
