Einleitung
This guide consist of a step by step instruction on how to remove your battery, make clean tidy room with enough lighting before you start. In addition, make sure your battery actually needs to be replaced by turning to our troubleshooting guide
Was du brauchst
Remove the four screws from the battery using a Phillips #0 screwdriver.
For optimal performance, after completing this guide, calibrate your newly installed battery.
