Zum Hauptinhalt wechseln
HP Stream 8 Battery Replacement
Was du brauchst
    1. HP Stream 8 Battery Replacement, Midframe: Schritt 1, Bild 1 von 1
      • Use your nail or a spudger to pry the back cover off of the device.
      Frag FixBot
      Kommentar hinzufügen
    2. HP Stream 8 Battery Replacement: Schritt 2, Bild 1 von 1
      • Slide your finger around the rest of the back cover, lifting it completely off of the device.
      Frag FixBot
    3. HP Stream 8 Battery Replacement: Schritt 3, Bild 1 von 1
      • Remove ten Phillips #00 screws from the inside cover.
      Frag FixBot
    4. HP Stream 8 Battery Replacement: Schritt 4, Bild 1 von 1
      • Pry up the inside cover the same way as in the first step.
      Frag FixBot
    1. HP Stream 8 Battery Replacement, Front-Facing Camera: Schritt 5, Bild 1 von 1
      In diesem Schritt verwendetes Werkzeug:
      • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
      Frag FixBot
    2. HP Stream 8 Battery Replacement: Schritt 6, Bild 1 von 1
      • Remove the front facing camera with tweezers.
      Frag FixBot
    1. HP Stream 8 Battery Replacement, Rear-Facing Camera: Schritt 7, Bild 1 von 1
      • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
      Frag FixBot
    2. HP Stream 8 Battery Replacement: Schritt 8, Bild 1 von 1
      • Remove the back facing camera with the tweezers.
      Frag FixBot
    1. HP Stream 8 Battery Replacement, Motherboard: Schritt 9, Bild 1 von 1
      • Carefully remove the battery connector from the system board using the tweezers.
      Frag FixBot
    2. HP Stream 8 Battery Replacement: Schritt 10, Bild 1 von 1
      • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
      Frag FixBot
    3. HP Stream 8 Battery Replacement: Schritt 11, Bild 1 von 1
      • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
      Frag FixBot
    4. HP Stream 8 Battery Replacement: Schritt 12, Bild 1 von 1
      • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
      Frag FixBot
    5. HP Stream 8 Battery Replacement: Schritt 13, Bild 1 von 1
      • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
      Frag FixBot
    6. HP Stream 8 Battery Replacement: Schritt 14, Bild 1 von 1
      • Remove the motherboard from the device.
      Frag FixBot
    1. HP Stream 8 Battery Replacement, Battery: Schritt 15, Bild 1 von 1
      • Remove the 6 PH00 Phillips screws.
      Frag FixBot
    2. HP Stream 8 Battery Replacement: Schritt 16, Bild 1 von 1
      • The battery can now be removed from the device.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 34-14, Maness Spring 2016 Mitglied von Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Mitglieder
12 Anleitungen geschrieben
2 Kommentare zur Anleitung
We're I can buy battery for stream 8 tablet 4000mah
Marlon Ultado - Antwort Teilen
Bonjour,
pouvez-vous m'indiquer où je pourrais trouver une batterie compatible ?
Bien cordialement
GAVALDA - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 47
Insgesamt: 5,592
