Zum Hauptinhalt wechseln
HTC One Max Fingerprint Sensor Replacement
Was du brauchst
  1. HTC One Max Fingerprint Sensor Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
    Frag FixBot
    Kommentar hinzufügen
  2. HTC One Max Fingerprint Sensor Replacement: Schritt 2, Bild 1 von 2 HTC One Max Fingerprint Sensor Replacement: Schritt 2, Bild 2 von 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
    Frag FixBot
  3. HTC One Max Fingerprint Sensor Replacement: Schritt 3, Bild 1 von 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
    Frag FixBot
  4. HTC One Max Fingerprint Sensor Replacement: Schritt 4, Bild 1 von 2 HTC One Max Fingerprint Sensor Replacement: Schritt 4, Bild 2 von 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
    Frag FixBot
  5. HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: Schritt 5, Bild 1 von 2 HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
    Frag FixBot
Abschluss
USF Tampa, Team 11-3, Blackwell Fall 2014 Mitglied von USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 25
Insgesamt: 1,582
