Zum Hauptinhalt wechseln
HTC Rhyme Volume Button Replacement
Was du brauchst
  1. HTC Rhyme Volume Button  Replacement, Removing Back Cover: Schritt 1, Bild 1 von 1
    • Slide the bottom back cover off of the phone.
    Frag FixBot
    Kommentar hinzufügen
  2. HTC Rhyme Volume Button  Replacement: Schritt 2, Bild 1 von 1
    • Locate the four screws on the plastic cover and unscrew them.
    Frag FixBot
  3. HTC Rhyme Volume Button  Replacement: Schritt 3, Bild 1 von 1
    • Pry the sticker off from the sides.
    • You can use a metal spudger to do this.
    • Peel the sticker off with your hands.
    Frag FixBot
  4. HTC Rhyme Volume Button  Replacement, Remove the plastic cover: Schritt 4, Bild 1 von 1
    • Remove the plastic cover using your hands.
    Frag FixBot
  5. HTC Rhyme Volume Button  Replacement: Schritt 5, Bild 1 von 1
    • Remove the yellow ribbon.
    Frag FixBot
  6. HTC Rhyme Volume Button  Replacement: Schritt 6, Bild 1 von 3 HTC Rhyme Volume Button  Replacement: Schritt 6, Bild 2 von 3 HTC Rhyme Volume Button  Replacement: Schritt 6, Bild 3 von 3
    • Lift up the blue flaps underneath the battery.
    • Lift up the black flap at the top of the phone.
    • Lift up the black flap at the bottom of the phone.
    Frag FixBot
  7. HTC Rhyme Volume Button  Replacement, Remove the Motherboard: Schritt 7, Bild 1 von 2 HTC Rhyme Volume Button  Replacement, Remove the Motherboard: Schritt 7, Bild 2 von 2
    • Remove all 4 screws.
    • Carefully remove the motherboard with your hands.
    Frag FixBot
  8. HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: Schritt 8, Bild 1 von 3 HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: Schritt 8, Bild 2 von 3 HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: Schritt 8, Bild 3 von 3
    • Pry the back plastic casing off with your hands.
    Frag FixBot
  9. HTC Rhyme Volume Button  Replacement: Schritt 9, Bild 1 von 2 HTC Rhyme Volume Button  Replacement: Schritt 9, Bild 2 von 2
    • Use the tip of a screwdriver to push the button out of the panel.
    Frag FixBot
Abschluss
USF Tampa, Team 9-6, Leahy Fall 2014 Mitglied von USF Tampa, Team 9-6, Leahy Fall 2014
USFT-LEAHY-F14S9G6
3 Mitglieder
15 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 32
Insgesamt: 498
