Zum Hauptinhalt wechseln
HTC Vive Pro All-In-One Cable Replacement
Was du brauchst
  1. HTC Vive Pro All-In-One Cable Replacement, Reposition the head strap: Schritt 1, Bild 1 von 2 HTC Vive Pro All-In-One Cable Replacement, Reposition the head strap: Schritt 1, Bild 2 von 2
    • Rotate the head strap forward as far as it will go.
  2. HTC Vive Pro All-In-One Cable Replacement, Unplug the All-In-One Cable: Schritt 2, Bild 1 von 2 HTC Vive Pro All-In-One Cable Replacement, Unplug the All-In-One Cable: Schritt 2, Bild 2 von 2
    • Unplug the All-In-One Cable from your headset.
  3. HTC Vive Pro All-In-One Cable Replacement, Remove the All-In-One Cable: Schritt 3, Bild 1 von 3 HTC Vive Pro All-In-One Cable Replacement, Remove the All-In-One Cable: Schritt 3, Bild 2 von 3 HTC Vive Pro All-In-One Cable Replacement, Remove the All-In-One Cable: Schritt 3, Bild 3 von 3
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
Abschluss
Sam Omiotek
97.133 Reputation
290 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 29
Letzte 30 Tage: 81
Insgesamt: 3,857
