Zum Hauptinhalt wechseln
HTC Vive Pro Daughterboard Replacement
Was du brauchst
  1. HTC Vive Pro Daughterboard Replacement, Reposition the head strap: Schritt 1, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement, Reposition the head strap: Schritt 1, Bild 2 von 2
    • Rotate the head strap forward as far as it will go.
  2. HTC Vive Pro Daughterboard Replacement, Unplug the All-In-One Cable: Schritt 2, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement, Unplug the All-In-One Cable: Schritt 2, Bild 2 von 2
    • Unplug the All-In-One Cable from your headset.
  3. HTC Vive Pro Daughterboard Replacement, Remove the All-In-One Cable: Schritt 3, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement, Remove the All-In-One Cable: Schritt 3, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement, Remove the All-In-One Cable: Schritt 3, Bild 3 von 3
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. HTC Vive Pro Daughterboard Replacement, Remove the top strap: Schritt 4, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement, Remove the top strap: Schritt 4, Bild 2 von 2
    • Separate the top strap from itself where the Velcro secures it.
  5. HTC Vive Pro Daughterboard Replacement: Schritt 5, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 5, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 5, Bild 3 von 3
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to partially remove it.
  6. HTC Vive Pro Daughterboard Replacement: Schritt 6, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 6, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 6, Bild 3 von 3
    • Feed the top strap through the clip near the front of headset to fully remove it.
  7. HTC Vive Pro Daughterboard Replacement, Remove the front side foam pads: Schritt 7, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement, Remove the front side foam pads: Schritt 7, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement, Remove the front side foam pads: Schritt 7, Bild 3 von 3
    • Peel off both front side foam pads to uncover the speaker wires.
  8. HTC Vive Pro Daughterboard Replacement, Remove the two rubber spacers: Schritt 8, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement, Remove the two rubber spacers: Schritt 8, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement, Remove the two rubber spacers: Schritt 8, Bild 3 von 3
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. HTC Vive Pro Daughterboard Replacement, Disconnect the speaker wires: Schritt 9, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement, Disconnect the speaker wires: Schritt 9, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement, Disconnect the speaker wires: Schritt 9, Bild 3 von 3
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. HTC Vive Pro Daughterboard Replacement, Remove the head strap: Schritt 10, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement, Remove the head strap: Schritt 10, Bild 2 von 2
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. HTC Vive Pro Daughterboard Replacement: Schritt 11, Bild 1 von 1
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
  12. HTC Vive Pro Daughterboard Replacement: Schritt 12, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 12, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 12, Bild 3 von 3
    • Thread the headphone speaker wires out through both ends of the head strap.
  13. HTC Vive Pro Daughterboard Replacement, Remove the outer shell: Schritt 13, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement, Remove the outer shell: Schritt 13, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement, Remove the outer shell: Schritt 13, Bild 3 von 3
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
  14. HTC Vive Pro Daughterboard Replacement: Schritt 14, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement: Schritt 14, Bild 2 von 2
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
  15. HTC Vive Pro Daughterboard Replacement: Schritt 15, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 15, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 15, Bild 3 von 3
    • Insert an opening pick into the seam between the two halves of the outer shell.
    • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
  16. HTC Vive Pro Daughterboard Replacement: Schritt 16, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 16, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 16, Bild 3 von 3
    • Continue sliding the opening pick through each seam until all clips have been dislodged.
  17. HTC Vive Pro Daughterboard Replacement: Schritt 17, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 17, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 17, Bild 3 von 3
    • Carefully slide each half of the outer shell off of the sensor array.
    • Be careful not to snag any of the ribbon cables underneath.
  18. HTC Vive Pro Daughterboard Replacement, Remove the face rest cushion: Schritt 18, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement, Remove the face rest cushion: Schritt 18, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement, Remove the face rest cushion: Schritt 18, Bild 3 von 3
    • Use your fingers to gently peel the face rest cushion off of the headset.
  19. HTC Vive Pro Daughterboard Replacement, Remove the facerest: Schritt 19, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement, Remove the facerest: Schritt 19, Bild 2 von 2
    • Partially separate the facerest and the sensor array to access the daughterboard.
  20. HTC Vive Pro Daughterboard Replacement: Schritt 20, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement: Schritt 20, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to remove the Kapton tape covering the white and purple wires on the daughterboard.
  21. HTC Vive Pro Daughterboard Replacement: Schritt 21, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 21, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 21, Bild 3 von 3
    • Use the pointed end of a spudger to pry up and disconnect the purple and white wires from the daughterboard.
    • Use caution when disconnecting these wires. If you pry up too hard, they may pull out of the connector.
  22. HTC Vive Pro Daughterboard Replacement: Schritt 22, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement: Schritt 22, Bild 2 von 2
    • Slide the facerest out of the front assembly.
  23. HTC Vive Pro Daughterboard Replacement, Remove the sensor array: Schritt 23, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement, Remove the sensor array: Schritt 23, Bild 2 von 2
    • Use a pair of tweezers to remove the Kapton tape covering the ZIF connector on the daughterboard.
  24. HTC Vive Pro Daughterboard Replacement: Schritt 24, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 24, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 24, Bild 3 von 3
    • Use the pointed end of a spudger to flip up the locking flap on the daughterboard ZIF connector.
    • Use a pair of tweezers to slide the ribbon cable out of its socket.
  25. HTC Vive Pro Daughterboard Replacement: Schritt 25, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement: Schritt 25, Bild 2 von 2
    • Use a pair of tweezers to peel back the grey tape covering the ZIF connector on the motherboard underneath the sensor array.
  26. HTC Vive Pro Daughterboard Replacement: Schritt 26, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 26, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 26, Bild 3 von 3
    • Use the flat end of your spudger to flip up the locking flap for the ZIF connector on the motherboard.
    • Use the pointed end of your spudger to disconnect the ribbon cable from the motherboard.
  27. HTC Vive Pro Daughterboard Replacement: Schritt 27, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement: Schritt 27, Bild 2 von 2
    • Use a T5 Torx screwdriver to remove the four 3.0 mm silver screws securing the sensor array to the lens and OLED assembly.
    • Use a T6 Torx screwdriver to remove the four black 3.8 mm screws securing the sensor array.
  28. HTC Vive Pro Daughterboard Replacement: Schritt 28, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement: Schritt 28, Bild 2 von 2
    • Lift the sensor array straight up off of the lens and OLED assembly.
  29. HTC Vive Pro Daughterboard Replacement, Remove the daughterboard: Schritt 29, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement, Remove the daughterboard: Schritt 29, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement, Remove the daughterboard: Schritt 29, Bild 3 von 3
    • Use the flat end of your spudger to disconnect the two press connectors from the daughterboard.
  30. HTC Vive Pro Daughterboard Replacement: Schritt 30, Bild 1 von 2 HTC Vive Pro Daughterboard Replacement: Schritt 30, Bild 2 von 2
    • Use a pair of tweezers to remove the Kapton tape covering the last remaining ZIF connector.
  31. HTC Vive Pro Daughterboard Replacement: Schritt 31, Bild 1 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 31, Bild 2 von 3 HTC Vive Pro Daughterboard Replacement: Schritt 31, Bild 3 von 3
    • Use the pointed end of your spudger to flip up the locking flap on the ZIF connector.
    • Use a pair of tweezers to disconnect the ribbon cable from the ZIF connector.
  32. HTC Vive Pro Daughterboard Replacement: Schritt 32, Bild 1 von 1
    • Use a T5 Torx screwdriver to remove the four 3.0 mm screws securing the daughterboard.
  33. HTC Vive Pro Daughterboard Replacement: Schritt 33, Bild 1 von 1
    • Remove the daughterboard.
    • During reassembly, don't forget to reinstall any Kapton tape that was removed during disassembly. This will prevent malfunction of the sensors.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Sam Omiotek
98.041 Reputation
290 Anleitungen geschrieben
2 Kommentare zur Anleitung
Hi!
I've got a problem where the port itself seems to be the problem. the vive pro connects and disconnects contantly when you shake the cable a bit.
is there a simple fix?
1BalBal1 - Antwort Teilen
Unfort, no. The female port on the daughterboard has became loose from the solder and the daughterboard needs to be either replaced or the video/audio port needs to be re-soldered. There just simply is no ...easy fix.
Crystal Stanford - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 17
Letzte 30 Tage: 44
Insgesamt: 1,528
