Einleitung
Follow this guide to replace the lens and OLED assembly in your HTC Vive Pro.
Power off and unplug your headset before you begin your repair.
Was du brauchst
Remove the All-In-One Cable from the cable guides along the left side of the head strap.
Separate the top strap from itself where the Velcro secures it.
Peel back the Velcro securing the rear of the top strap.
Feed the top strap out through the head strap to partially remove it.
Feed the top strap through the clip near the front of headset to fully remove it.
Peel off both front side foam pads to uncover the speaker wires.
Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
Four 3.9 mm screws (two on each side)
Two 4.1 mm screws (one on each side)
Remove the two plastic spacers underneath the previously removed Torx T6 screw.
Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
Insert an opening pick into the seam between the two halves of the outer shell.
Slide the opening pick through the seam to dislodge the clips securing it to the headset.
Continue sliding the opening pick through each seam until all clips have been dislodged.
Use your fingers to gently peel the face rest cushion off of the headset.
Partially separate the facerest and the sensor array to access the daughterboard.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a pair of tweezers to remove the Kapton tape covering the white and purple wires on the daughterboard.
Use the pointed end of a spudger to pry up and disconnect the purple and white wires from the daughterboard.
Use a pair of tweezers to remove the Kapton tape covering the ZIF connector on the daughterboard.
Use the pointed end of a spudger to flip up the locking flap on the daughterboard ZIF connector.
Use a pair of tweezers to slide the ribbon cable out of its socket.
Use a pair of tweezers to peel back the grey tape covering the ZIF connector on the motherboard underneath the sensor array.
Use the flat end of your spudger to flip up the locking flap for the ZIF connector on the motherboard.
Use the pointed end of your spudger to disconnect the ribbon cable from the motherboard.
Use a T5 Torx screwdriver to remove the four 3.0 mm silver screws securing the sensor array to the lens and OLED assembly.
Use a T6 Torx screwdriver to remove the four black 3.8 mm screws securing the sensor array.
Use the flat end of your spudger to disconnect the two press connectors from the daughterboard.
Use a pair of tweezers to remove the Kapton tape covering the last remaining ZIF connector.
Use the pointed end of your spudger to flip up the locking flap on the ZIF connector.
Use a pair of tweezers to disconnect the ribbon cable from the ZIF connector.
Use a T5 Torx screwdriver to remove the four 3.0 mm screws securing the daughterboard.
