Zum Hauptinhalt wechseln
HTC Wizard 100 Camera Replacement
Was du brauchst
  1. HTC Wizard 100 Camera Replacement, Battery: Schritt 1, Bild 1 von 2 HTC Wizard 100 Camera Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
    Frag FixBot
    Kommentar hinzufügen
  2. HTC Wizard 100 Camera Replacement: Schritt 2, Bild 1 von 2 HTC Wizard 100 Camera Replacement: Schritt 2, Bild 2 von 2
    • Pull on the plastic tab to release the battery.
    Frag FixBot
  3. HTC Wizard 100 Camera Replacement, Back Case: Schritt 3, Bild 1 von 2 HTC Wizard 100 Camera Replacement, Back Case: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
    Frag FixBot
  4. HTC Wizard 100 Camera Replacement: Schritt 4, Bild 1 von 1
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
    Frag FixBot
  5. HTC Wizard 100 Camera Replacement: Schritt 5, Bild 1 von 3 HTC Wizard 100 Camera Replacement: Schritt 5, Bild 2 von 3 HTC Wizard 100 Camera Replacement: Schritt 5, Bild 3 von 3
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
    Frag FixBot
  6. HTC Wizard 100 Camera Replacement, Camera: Schritt 6, Bild 1 von 1
    • Locate the camera and pry off with the plastic opening tool or spudger.
    Frag FixBot
Abschluss
Cal Poly, Team 20-28, Maness Fall 2011 Mitglied von Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Mitglieder
21 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 1,059
