Zum Hauptinhalt wechseln
HTC Wizard 100 Screen Replacement
Was du brauchst
  1. HTC Wizard 100 Screen Replacement, Battery: Schritt 1, Bild 1 von 2 HTC Wizard 100 Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
    Frag FixBot
    Kommentar hinzufügen
  2. HTC Wizard 100 Screen Replacement: Schritt 2, Bild 1 von 2 HTC Wizard 100 Screen Replacement: Schritt 2, Bild 2 von 2
    • Pull on the plastic tab to release the battery.
    Frag FixBot
  3. HTC Wizard 100 Screen Replacement, Back Case: Schritt 3, Bild 1 von 2 HTC Wizard 100 Screen Replacement, Back Case: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
    Frag FixBot
  4. HTC Wizard 100 Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
    Frag FixBot
  5. HTC Wizard 100 Screen Replacement: Schritt 5, Bild 1 von 3 HTC Wizard 100 Screen Replacement: Schritt 5, Bild 2 von 3 HTC Wizard 100 Screen Replacement: Schritt 5, Bild 3 von 3
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
    Frag FixBot
  6. HTC Wizard 100 Screen Replacement, Speakers: Schritt 6, Bild 1 von 2 HTC Wizard 100 Screen Replacement, Speakers: Schritt 6, Bild 2 von 2
    • Grip the speaker connector with your thumb and finger and gently pull up.
    • Repeat for 2nd speaker.
    Frag FixBot
  7. HTC Wizard 100 Screen Replacement, Camera: Schritt 7, Bild 1 von 1
    • Locate the camera and pry off with the plastic opening tool or spudger.
    Frag FixBot
  8. HTC Wizard 100 Screen Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Remove the 3.4 mm black screw with the Phillips #000 screwdriver.
    Frag FixBot
  9. HTC Wizard 100 Screen Replacement: Schritt 9, Bild 1 von 2 HTC Wizard 100 Screen Replacement: Schritt 9, Bild 2 von 2
    • Remove the plastic tape to reveal the connector.
    • Use your finger or plastic opening tool to flip the connector and release the cable.
    Frag FixBot
  10. HTC Wizard 100 Screen Replacement: Schritt 10, Bild 1 von 2 HTC Wizard 100 Screen Replacement: Schritt 10, Bild 2 von 2
    • Use the plastic opening tool to carefully lift the motherboard off one corner at a time.
    • Lift the motherboard slowly away from the keyboard because there is a cable attached to bottom of the motherboard.
    • If the motherboard is not easily removed by pulling, then lift one side of the motherboard until you can see the attached cable. Then use the plastic opening tool to detach the cable from the motherboard.
    Frag FixBot
  11. HTC Wizard 100 Screen Replacement, Screen: Schritt 11, Bild 1 von 2 HTC Wizard 100 Screen Replacement, Screen: Schritt 11, Bild 2 von 2
    • Using the Phillips Screwdriver #000 remove the four 3.3 mm screws.
    • Carefully lift the keyboard from the plastic plate by allowing the ribbon cable to slip through the opening of the plastic plate.
    Frag FixBot
  12. HTC Wizard 100 Screen Replacement: Schritt 12, Bild 1 von 1
    • Use the Phillips Screwdriver #000 to remove the four 3.8 mm screws from the back of the screen.
    Frag FixBot
  13. HTC Wizard 100 Screen Replacement: Schritt 13, Bild 1 von 3 HTC Wizard 100 Screen Replacement: Schritt 13, Bild 2 von 3 HTC Wizard 100 Screen Replacement: Schritt 13, Bild 3 von 3
    • Insert the spudger between the panel and the case.
    • Gently pry off the panel by rotating or wiggling the spudger back and forth.
    • Lift the panel off while allowing the ribbon to slip through the opening.
    Frag FixBot
  14. HTC Wizard 100 Screen Replacement: Schritt 14, Bild 1 von 3 HTC Wizard 100 Screen Replacement: Schritt 14, Bild 2 von 3 HTC Wizard 100 Screen Replacement: Schritt 14, Bild 3 von 3
    • Remove the four 2.9 mm screws with the Phillips Screwdriver #000.
    • Use your fingers to separate the screen assembly from the front panel.
    Frag FixBot
  15. HTC Wizard 100 Screen Replacement: Schritt 15, Bild 1 von 2 HTC Wizard 100 Screen Replacement: Schritt 15, Bild 2 von 2
    • Insert the spudger between the green panel and the screen itself.
    • Gently wiggle the spudger to pry them apart.
    Frag FixBot
  16. HTC Wizard 100 Screen Replacement: Schritt 16, Bild 1 von 3 HTC Wizard 100 Screen Replacement: Schritt 16, Bild 2 von 3 HTC Wizard 100 Screen Replacement: Schritt 16, Bild 3 von 3
    • Remove the tape.
    • Locate the connecting ribbon.
    • Using the spudger or your thumb and finger, flip the switch up and disconnect the ribbon.
    • Lift off the panel from the screen.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 20-28, Maness Fall 2011 Mitglied von Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Mitglieder
27 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 31
Insgesamt: 1,353
