Zum Hauptinhalt wechseln
Hamilton Beach 51101BA Power Button Replacement
Was du brauchst
    1. Hamilton Beach 51101BA Power Button Replacement, Power Button: Schritt 1, Bild 1 von 3 Hamilton Beach 51101BA Power Button Replacement, Power Button: Schritt 1, Bild 2 von 3 Hamilton Beach 51101BA Power Button Replacement, Power Button: Schritt 1, Bild 3 von 3
      • Remove the container from the base.
      • Hold the blender and the container, then twist the container in a clockwise motion.
      • Make sure to follow the lock and unlock markings on the container.
      Frag FixBot
      Kommentar hinzufügen
    2. Hamilton Beach 51101BA Power Button Replacement: Schritt 2, Bild 1 von 1
      • Turn the blender so the bottom is facing you.
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
      Frag FixBot
    3. Hamilton Beach 51101BA Power Button Replacement: Schritt 3, Bild 1 von 1
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
      Frag FixBot
    4. Hamilton Beach 51101BA Power Button Replacement: Schritt 4, Bild 1 von 2 Hamilton Beach 51101BA Power Button Replacement: Schritt 4, Bild 2 von 2
      • Unhinge the motor platform from the blender.
      • You may need a plastic spudger to unhinge the plastic bottom piece from the base of the blender.
      • You do not need to completely remove this piece from the base.
      Frag FixBot
    5. Hamilton Beach 51101BA Power Button Replacement: Schritt 5, Bild 1 von 1
      • Pull out the rectangular green piece.
      • This is the actual power button.
      Frag FixBot
    6. Hamilton Beach 51101BA Power Button Replacement: Schritt 6, Bild 1 von 1
      • Some experience in soldering is required!
      • On the back of the power button, desolder the red and grey wires that are connected to the piece.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 2-5, Sullivan Fall 2015 Mitglied von USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 30
Insgesamt: 4,045
