Einleitung
This guide shows how to remove and replace the stator for the Honda 6500 Watt Generator EG6500CL AT.
This procedure shows how to complete the procedure without removing the generator from the frame.
You will need some wooden blocks that are about 2.5 inches tall to support the generator.
Was du brauchst
Before you work on the device, make sure to switch the engine off.
Switch the circuit breaker off.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a Phillips screwdriver to remove the two screws securing the generator cover.
Squeeze and disconnect the stator connector from the wiring harness.
Use a 10 mm socket to remove the bolt securing the brush assembly.
Pull the brush assembly out slightly from its recess.
Use a 10 mm socket to remove the four long bolts securing the generator cover to the generator assembly.
Use an 8 mm socket to remove the four nuts securing the wiring harness to the terminal.
Remove the wiring harness wires from the terminal.
Base washer
Crush washer
Stator wire connector
Nut
Wiring harness connector
Crush washer
Nut
Use an 8 mm socket to remove the three bolts securing the wiring terminal and harness.
Remove the Phillips screw securing the harness ground.
Loosen the wiring terminal and harness from their resting positions.
Use pliers to release the cable tie securing the wiring harness to the generator assembly.
Carefully tilt the rear of the generator upwards to access the under-frame bolts.
Use a 12 mm socket to remove the two bolts underneath the frame, which secures the rear generator housing.
Use a 14 mm socket to remove the mounting nut next to the emissions canister.
Use a 14 mm socket to remove the mounting nut near the oil filler hole.
Use a 14 mm socket to remove the two nuts securing the rear housing to the bushings.
Tilt the generator assembly by lifting the rear housing slightly.
Place support blocks underneath the silver generator housing to support the generator assembly.
Lift the rear generator housing up as far as you can and maneuver the left bushing out of its socket.
Remove the left bushing.
Remove the rear generator housing from the generator assembly.
Rotate the stator cover so that the seam is at an accessible angle.
Use a flathead screwdriver to pry up the tabs holding the stator cover together.
Remove the stator by pulling it straight out of the generator assembly.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
