Zum Hauptinhalt wechseln
Honda EU2200IT A2 Carburetor Replacement
Was du brauchst
  1. Honda EU2200IT A2 Carburetor Replacement, Honda EU2200IT A2 Safety Precautions: Schritt 1, Bild 1 von 1
    • Before you begin, make sure the generator is switched off and the generator is cool to the touch.
  2. Honda EU2200IT A2 Carburetor Replacement, Disconnect the spark plug: Schritt 2, Bild 1 von 2 Honda EU2200IT A2 Carburetor Replacement, Disconnect the spark plug: Schritt 2, Bild 2 von 2
    • Lift and remove the spark plug cover.
  3. Honda EU2200IT A2 Carburetor Replacement: Schritt 3, Bild 1 von 2 Honda EU2200IT A2 Carburetor Replacement: Schritt 3, Bild 2 von 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Honda EU2200IT A2 Carburetor Replacement, Remove the maintenance cover: Schritt 4, Bild 1 von 1
    • Use a Phillips #2 screwdriver to loosen the screw holding the maintenance cover in place.
  5. Honda EU2200IT A2 Carburetor Replacement: Schritt 5, Bild 1 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 5, Bild 2 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 5, Bild 3 von 3
    • Swing the top of the maintenance cover out.
    • Remove the maintenance cover.
  6. Honda EU2200IT A2 Carburetor Replacement, Drain the carburetor fuel bowl: Schritt 6, Bild 1 von 1
    • Place a container below the drain tube to catch the excess fuel.
  7. Honda EU2200IT A2 Carburetor Replacement: Schritt 7, Bild 1 von 2 Honda EU2200IT A2 Carburetor Replacement: Schritt 7, Bild 2 von 2
    • The carburetor drain screw is located at the bottom of the carburetor.
    • Use a flathead screwdriver to loosen the fuel drain screw until fuel begins to drain out of the carburetor.
    • Once you drain the fuel bowl, re-tighten the fuel drain screw.
  8. Honda EU2200IT A2 Carburetor Replacement, Remove the air filters: Schritt 8, Bild 1 von 1
    • Remove the Phillips screw securing the filter cover.
    • During reassembly, be sure to tighten the screw to at least 1.7 ft-lb to prevent it from loosening during operation.
  9. Honda EU2200IT A2 Carburetor Replacement: Schritt 9, Bild 1 von 2 Honda EU2200IT A2 Carburetor Replacement: Schritt 9, Bild 2 von 2
    • Remove the filter cover.
  10. Honda EU2200IT A2 Carburetor Replacement: Schritt 10, Bild 1 von 2 Honda EU2200IT A2 Carburetor Replacement: Schritt 10, Bild 2 von 2
    • Remove the air filters from the filter box.
    • To clean the filters:
    • Clean the filters in warm soapy water.
    • Allow the filters to dry thoroughly.
    • Dip the filters in clean engine oil, and squeeze out any excess oil.
  11. Honda EU2200IT A2 Carburetor Replacement, Remove the air cleaner housing: Schritt 11, Bild 1 von 3 Honda EU2200IT A2 Carburetor Replacement, Remove the air cleaner housing: Schritt 11, Bild 2 von 3 Honda EU2200IT A2 Carburetor Replacement, Remove the air cleaner housing: Schritt 11, Bild 3 von 3
    • Use a flathead screwdriver to loosen the breather tube from the air cleaner housing.
    • Disconnect the breather tube from the air cleaner housing.
  12. Honda EU2200IT A2 Carburetor Replacement: Schritt 12, Bild 1 von 1
    • Remove the following fasteners securing the housing:
    • Two 8 mm nuts
    • During reassembly, tighten these to 3.6 ft-lb.
    • One 8 mm bolt
  13. Honda EU2200IT A2 Carburetor Replacement: Schritt 13, Bild 1 von 2 Honda EU2200IT A2 Carburetor Replacement: Schritt 13, Bild 2 von 2
    • Remove the air cleaner housing.
  14. Honda EU2200IT A2 Carburetor Replacement: Schritt 14, Bild 1 von 1
    • During reassembly, replace the air intake gasket if it shows signs of wear.
  15. Honda EU2200IT A2 Carburetor Replacement, Remove the carburetor: Schritt 15, Bild 1 von 2 Honda EU2200IT A2 Carburetor Replacement, Remove the carburetor: Schritt 15, Bild 2 von 2
    • Fuel may leak out when you disconnect this hose. Be ready to catch any spillage.
    • Use a pair of pliers to squeeze and slide the spring clip off the carburetor fuel intake.
  16. Honda EU2200IT A2 Carburetor Replacement: Schritt 16, Bild 1 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 16, Bild 2 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 16, Bild 3 von 3
    • Pry and disconnect the fuel hose from the carburetor intake.
  17. Honda EU2200IT A2 Carburetor Replacement: Schritt 17, Bild 1 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 17, Bild 2 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 17, Bild 3 von 3
    • Residual fuel may leak out of the carburetor. Be ready to contain any spillage.
    • Slide the carburetor off its two bolt rails.
  18. Honda EU2200IT A2 Carburetor Replacement: Schritt 18, Bild 1 von 1
    • During reassembly, use this photo as a reference for how to route the tubing.
  19. Honda EU2200IT A2 Carburetor Replacement: Schritt 19, Bild 1 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 19, Bild 2 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 19, Bild 3 von 3
    • The throttle control cover is held in place with three clips.
    • Unclip and remove the throttle control cover.
  20. Honda EU2200IT A2 Carburetor Replacement: Schritt 20, Bild 1 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 20, Bild 2 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 20, Bild 3 von 3
    • Disconnect the throttle control cable from the carburetor.
    • During reassembly, use the third image as a reference for how to route the control cable.
  21. Honda EU2200IT A2 Carburetor Replacement: Schritt 21, Bild 1 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 21, Bild 2 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 21, Bild 3 von 3
    • Slide the air vent tube out of the tube clip on the side of the carburetor.
    • Remove the tube clip from the side of the carburetor and transfer it to your replacement part.
  22. Honda EU2200IT A2 Carburetor Replacement: Schritt 22, Bild 1 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 22, Bild 2 von 3 Honda EU2200IT A2 Carburetor Replacement: Schritt 22, Bild 3 von 3
    • Pull the air vent tube and drain tube out of the port holes on the bottom of the cover.
  23. Honda EU2200IT A2 Carburetor Replacement: Schritt 23, Bild 1 von 2 Honda EU2200IT A2 Carburetor Replacement: Schritt 23, Bild 2 von 2
    • Remove the tube clip bridging the vent tubes.
    • Transfer the tube clip to your replacement carburetor.
  24. Honda EU2200IT A2 Carburetor Replacement: Schritt 24, Bild 1 von 2 Honda EU2200IT A2 Carburetor Replacement: Schritt 24, Bild 2 von 2
    • Remove the carburetor along with any attached tubing.
    • Compare your replacement part with the original, and transfer over any missing components.
  25. Honda EU2200IT A2 Carburetor Replacement: Schritt 25, Bild 1 von 1
    • Replace the carburetor seal if it shows signs of wear.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Arthur Shi
238.111 Reputation
474 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
140 Mitglieder
15.219 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 90
Insgesamt: 1,746
