Zum Hauptinhalt wechseln
Honda EU2200IT A2 Rotor Replacement
Was du brauchst
  1. Honda EU2200IT A2 Rotor Replacement, Honda EU2200IT A2 Safety Precautions: Schritt 1, Bild 1 von 1
    • Before you begin, make sure the generator is switched off and the generator is cool to the touch.
  2. Honda EU2200IT A2 Rotor Replacement, Disconnect the spark plug: Schritt 2, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement, Disconnect the spark plug: Schritt 2, Bild 2 von 2
    • Lift and remove the spark plug cover.
  3. Honda EU2200IT A2 Rotor Replacement: Schritt 3, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 3, Bild 2 von 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Honda EU2200IT A2 Rotor Replacement, Remove the maintenance cover: Schritt 4, Bild 1 von 1
    • Use a Phillips #2 screwdriver to loosen the screw holding the maintenance cover in place.
  5. Honda EU2200IT A2 Rotor Replacement: Schritt 5, Bild 1 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 5, Bild 2 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 5, Bild 3 von 3
    • Swing the top of the maintenance cover out.
    • Remove the maintenance cover.
  6. Honda EU2200IT A2 Rotor Replacement, Drain the engine oil: Schritt 6, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement, Drain the engine oil: Schritt 6, Bild 2 von 2
    • Unscrew and remove the oil filler cap.
  7. Honda EU2200IT A2 Rotor Replacement: Schritt 7, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 7, Bild 2 von 2
    • Place an oil pan below the fill port to catch the engine oil.
    • Carefully tilt the generator towards the oil pan to drain the oil.
  8. Honda EU2200IT A2 Rotor Replacement: Schritt 8, Bild 1 von 1
    • During reassembly, be sure to refill the engine oil:
    • If you recently resealed the crankcase cover with liquid sealant, wait at least 20 minutes before adding oil.
    • Use SAE 10W-30 oil, up to 0.46 US quarts.
    • Add oil until the dipstick is almost completely submerged.
  9. Honda EU2200IT A2 Rotor Replacement, Drain the carburetor fuel bowl: Schritt 9, Bild 1 von 1
    • Place a container below the drain tube to catch the excess fuel.
  10. Honda EU2200IT A2 Rotor Replacement: Schritt 10, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 10, Bild 2 von 2
    • The carburetor drain screw is located at the bottom of the carburetor.
    • Use a flathead screwdriver to loosen the fuel drain screw until fuel begins to drain out of the carburetor.
    • Once you drain the fuel bowl, re-tighten the fuel drain screw.
  11. Honda EU2200IT A2 Rotor Replacement, Back Cover: Schritt 11, Bild 1 von 1
    • Remove the four Phillips screws securing the back cover.
  12. Honda EU2200IT A2 Rotor Replacement: Schritt 12, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 12, Bild 2 von 2
    • Remove the back cover.
  13. Honda EU2200IT A2 Rotor Replacement, Loosen the front cover: Schritt 13, Bild 1 von 3 Honda EU2200IT A2 Rotor Replacement, Loosen the front cover: Schritt 13, Bild 2 von 3 Honda EU2200IT A2 Rotor Replacement, Loosen the front cover: Schritt 13, Bild 3 von 3
    • Remove the four screws securing the front cover:
    • Two Phillips screws
    • Two Phillips screws (one on each side)
  14. Honda EU2200IT A2 Rotor Replacement: Schritt 14, Bild 1 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 14, Bild 2 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 14, Bild 3 von 3
    • Swing the top edge of the front cover away from the generator.
    • Pull the front cover away slightly away.
    • The front cover still has many wires connected to it. Be careful not to strain any wires.
  15. Honda EU2200IT A2 Rotor Replacement, Remove the left cover: Schritt 15, Bild 1 von 3 Honda EU2200IT A2 Rotor Replacement, Remove the left cover: Schritt 15, Bild 2 von 3 Honda EU2200IT A2 Rotor Replacement, Remove the left cover: Schritt 15, Bild 3 von 3
    • Remove the lower gray plates from both sides of the generator.
    • During reassembly, be sure to reinstall the gray plate with the air vent cutout onto the right (access-side) cover.
  16. Honda EU2200IT A2 Rotor Replacement: Schritt 16, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 16, Bild 2 von 2
    • Remove the fasteners securing the left (non-access) cover:
    • Two 10 mm bolts
  17. Honda EU2200IT A2 Rotor Replacement: Schritt 17, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 17, Bild 2 von 2
    • Remove the left (non-access) cover.
  18. Honda EU2200IT A2 Rotor Replacement, Remove the right cover: Schritt 18, Bild 1 von 3 Honda EU2200IT A2 Rotor Replacement, Remove the right cover: Schritt 18, Bild 2 von 3 Honda EU2200IT A2 Rotor Replacement, Remove the right cover: Schritt 18, Bild 3 von 3
    • Slide the vent and drain tubes out of their cover ports along the bottom of the right cover.
  19. Honda EU2200IT A2 Rotor Replacement: Schritt 19, Bild 1 von 1
    • Remove the Phillips screw securing the starter rope port.
  20. Honda EU2200IT A2 Rotor Replacement: Schritt 20, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 20, Bild 2 von 2
    • Thread the starter rope handle through the port's cutout.
  21. Honda EU2200IT A2 Rotor Replacement: Schritt 21, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 21, Bild 2 von 2
    • Remove the right (access-side) cover.
  22. Honda EU2200IT A2 Rotor Replacement, Fuel Tank: Schritt 22, Bild 1 von 3 Honda EU2200IT A2 Rotor Replacement, Fuel Tank: Schritt 22, Bild 2 von 3 Honda EU2200IT A2 Rotor Replacement, Fuel Tank: Schritt 22, Bild 3 von 3
    • If you are replacing only the fuel tank, you can skip the next six steps.
    • Use a screwdriver to pry and loosen the diaphragm tube from the fuel pump.
    • Disconnect the diaphragm tube from the fuel pump.
  23. Honda EU2200IT A2 Rotor Replacement: Schritt 23, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 23, Bild 2 von 2
    • Use a pair of pliers to squeeze and slide the spring clip off the fuel pump port.
  24. Honda EU2200IT A2 Rotor Replacement: Schritt 24, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 24, Bild 2 von 2
    • Residual fuel may leak out of this hose. Be ready to contain any spillage.
    • Disconnect the fuel hose from the fuel pump.
  25. Honda EU2200IT A2 Rotor Replacement: Schritt 25, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 25, Bild 2 von 2
    • Pull and disconnect the engine stop switch connector from its socket.
  26. Honda EU2200IT A2 Rotor Replacement: Schritt 26, Bild 1 von 1
    • Remove the Phillips screw securing the starter rope guide.
  27. Honda EU2200IT A2 Rotor Replacement: Schritt 27, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 27, Bild 2 von 2
    • Feed the starter rope handle and guide through the panel cutout.
  28. Honda EU2200IT A2 Rotor Replacement, Remove the fuel tank: Schritt 28, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement, Remove the fuel tank: Schritt 28, Bild 2 von 2
    • Any residual fuel in the tank will leak. Be ready to contain any spillage.
    • Use a pair of pliers to squeeze and slide the spring clip off the fuel tank port.
  29. Honda EU2200IT A2 Rotor Replacement: Schritt 29, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 29, Bild 2 von 2
    • Disconnect the fuel line and filter from the fuel tank.
  30. Honda EU2200IT A2 Rotor Replacement: Schritt 30, Bild 1 von 1
    • Remove the Phillips screw securing the left (non-access) frame assembly.
  31. Honda EU2200IT A2 Rotor Replacement: Schritt 31, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 31, Bild 2 von 2
    • Remove the left (non-access) frame assembly.
  32. Honda EU2200IT A2 Rotor Replacement: Schritt 32, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 32, Bild 2 von 2
    • Lift and remove the fuel tank.
  33. Honda EU2200IT A2 Rotor Replacement, Remove the under-cover: Schritt 33, Bild 1 von 1
    • Use a flathead screwdriver to pry up the blue wire harness from the under-cover.
  34. Honda EU2200IT A2 Rotor Replacement: Schritt 34, Bild 1 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 34, Bild 2 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 34, Bild 3 von 3
    • Use a mallet and punch to tap out the front collar (closest to the electrical panel) securing the motor assembly to the under-cover.
  35. Honda EU2200IT A2 Rotor Replacement: Schritt 35, Bild 1 von 1
    • Use a 10 mm socket to remove the two bolts securing the motor rear to the under-cover.
  36. Honda EU2200IT A2 Rotor Replacement: Schritt 36, Bild 1 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 36, Bild 2 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 36, Bild 3 von 3
    • The motor assembly is heavy. Follow safe lifting practices when you lift the assembly.
    • Lift the motor assembly off the under-cover and set it aside.
  37. Honda EU2200IT A2 Rotor Replacement, Remove the left shroud: Schritt 37, Bild 1 von 1
    • Use a 10 mm socket to remove the two bolts securing the left shroud.
  38. Honda EU2200IT A2 Rotor Replacement: Schritt 38, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 38, Bild 2 von 2
    • Begin separating the left shroud from the engine assembly by pulling it away from the assembly.
    • The shroud sits in a groove on the engine assembly and may take some force to pull out.
  39. Honda EU2200IT A2 Rotor Replacement: Schritt 39, Bild 1 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 39, Bild 2 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 39, Bild 3 von 3
    • Pull along the edge of the shroud until you separate the shroud from the engine assembly.
    • Remove the shroud.
  40. Honda EU2200IT A2 Rotor Replacement, Remove the air filter housing: Schritt 40, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement, Remove the air filter housing: Schritt 40, Bild 2 von 2
    • Remove the Phillips screw securing the filter cover.
    • During reassembly, be sure to tighten the screw to at least 1.7 ft-lb to prevent it from loosening during operation.
    • Remove the filter cover.
  41. Honda EU2200IT A2 Rotor Replacement: Schritt 41, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 41, Bild 2 von 2
    • Remove the air filters from the filter box.
    • To clean the filters:
    • Clean the filters in warm soapy water
    • Allow the filters to dry thoroughly
    • Dip the filters in clean engine oil, and squeeze out excess oil
  42. Honda EU2200IT A2 Rotor Replacement: Schritt 42, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 42, Bild 2 von 2
    • Disconnect the breather tube from the air cleaner housing.
  43. Honda EU2200IT A2 Rotor Replacement: Schritt 43, Bild 1 von 1
    • Remove the following fasteners securing the housing:
    • Two 8 mm nuts
    • During reassembly, tighten these to 3.6 ft-lb.
    • One 8 mm bolt
  44. Honda EU2200IT A2 Rotor Replacement: Schritt 44, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 44, Bild 2 von 2
    • Remove the air filter housing.
  45. Honda EU2200IT A2 Rotor Replacement: Schritt 45, Bild 1 von 1
    • During reassembly, replace the air intake gasket if it shows signs of wear.
  46. Honda EU2200IT A2 Rotor Replacement: Schritt 46, Bild 1 von 1
    • During reassembly, use this photo as a reference for how to route the hoses.
  47. Honda EU2200IT A2 Rotor Replacement: Schritt 47, Bild 1 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 47, Bild 2 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 47, Bild 3 von 3
    • Unclip the fuel and air hoses from the side of the motor assembly.
  48. Honda EU2200IT A2 Rotor Replacement: Schritt 48, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 48, Bild 2 von 2
    • Pull the breather tube straight out of its port.
  49. Honda EU2200IT A2 Rotor Replacement: Schritt 49, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 49, Bild 2 von 2
    • Use a flathead screwdriver to unclip the carburetor wires from the side of the motor assembly.
  50. Honda EU2200IT A2 Rotor Replacement: Schritt 50, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 50, Bild 2 von 2
    • Slide the carburetor off its two bolt rails.
  51. Honda EU2200IT A2 Rotor Replacement: Schritt 51, Bild 1 von 1
    • During reassembly, replace the carburetor seal if it shows signs of wear.
  52. Honda EU2200IT A2 Rotor Replacement: Schritt 52, Bild 1 von 1
    • Use an 8 mm socket to remove the two bolts securing the carburetor insulator.
    • During reassembly, tighten these bolts to 2.2 ft-lb.
  53. Honda EU2200IT A2 Rotor Replacement: Schritt 53, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 53, Bild 2 von 2
    • Remove the carburetor insulator along with the two bolt rails.
  54. Honda EU2200IT A2 Rotor Replacement: Schritt 54, Bild 1 von 1
    • During reassembly, replace the insulator gasket if it shows signs of wear.
  55. Honda EU2200IT A2 Rotor Replacement: Schritt 55, Bild 1 von 1
    • Use a 10 mm socket to remove the bolts securing the right shroud.
  56. Honda EU2200IT A2 Rotor Replacement: Schritt 56, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 56, Bild 2 von 2
    • Begin separating the right shroud from the engine assembly by pulling it away from the assembly.
  57. Honda EU2200IT A2 Rotor Replacement: Schritt 57, Bild 1 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 57, Bild 2 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 57, Bild 3 von 3
    • Pull the shroud away along the edge. Use a flathead screwdriver to pry it out of the engine assembly groove.
  58. Honda EU2200IT A2 Rotor Replacement: Schritt 58, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 58, Bild 2 von 2
    • Remove the right shroud from the engine assembly.
  59. Honda EU2200IT A2 Rotor Replacement, Disconnect the wires: Schritt 59, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement, Disconnect the wires: Schritt 59, Bild 2 von 2
    • Use an 8 mm socket to remove the bolt securing the light green ground wire to the engine assembly.
  60. Honda EU2200IT A2 Rotor Replacement: Schritt 60, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 60, Bild 2 von 2
    • Use an 8 mm socket to remove the bolt securing the dark green ground wire to the engine assembly.
  61. Honda EU2200IT A2 Rotor Replacement: Schritt 61, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 61, Bild 2 von 2
    • Disconnect the wiring harness from the rectifier socket.
  62. Honda EU2200IT A2 Rotor Replacement: Schritt 62, Bild 1 von 1
    • Cut the zip tie securing the coil ignition wire to the harness.
  63. Honda EU2200IT A2 Rotor Replacement: Schritt 63, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 63, Bild 2 von 2
    • Disconnect the coil ignition wire from the harness by pulling it apart from both ends.
  64. Honda EU2200IT A2 Rotor Replacement, Remove the coil ignition assembly: Schritt 64, Bild 1 von 1
    • Use a 10 mm socket to remove the two bolts securing the coil ignition assembly.
  65. Honda EU2200IT A2 Rotor Replacement: Schritt 65, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 65, Bild 2 von 2
    • Unroute the coil ignition wire from the engine assembly.
  66. Honda EU2200IT A2 Rotor Replacement: Schritt 66, Bild 1 von 1
    • Remove the coil ignition assembly.
  67. Honda EU2200IT A2 Rotor Replacement, Remove the fan cover: Schritt 67, Bild 1 von 1
    • Use a 10 mm socket to remove the three bolts securing the fan cover.
  68. Honda EU2200IT A2 Rotor Replacement: Schritt 68, Bild 1 von 1
    • Pull the fan cover off the engine assembly.
  69. Honda EU2200IT A2 Rotor Replacement, Reassembly tip: Schritt 69, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement, Reassembly tip: Schritt 69, Bild 2 von 2
    • During reassembly, make sure that the cable strain relief sits properly in its fan cover cutout.
  70. Honda EU2200IT A2 Rotor Replacement, Remove the cooling fan: Schritt 70, Bild 1 von 1
    • Use a 10 mm socket to remove the two bolts securing the cooling fan.
  71. Honda EU2200IT A2 Rotor Replacement: Schritt 71, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 71, Bild 2 von 2
    • Remove the cooling fan, fan set plate, and starter pulley.
  72. Honda EU2200IT A2 Rotor Replacement, Remove the rotor: Schritt 72, Bild 1 von 1
    • Use a 19 mm socket to remove the nut securing the rotor.
    • This nut is heavily bolted on. Use an impact wrench to loosen it, or use a breaker bar with a strap wrench to break it free.
    • During reassembly, tighten this nut to 66 lb-ft.
  73. Honda EU2200IT A2 Rotor Replacement: Schritt 73, Bild 1 von 2 Honda EU2200IT A2 Rotor Replacement: Schritt 73, Bild 2 von 2
    • Attach a flywheel puller to the rotor and attach the collar bolts to the marked holes.
    • Use the flywheel puller to loosen the rotor from the axle.
  74. Honda EU2200IT A2 Rotor Replacement: Schritt 74, Bild 1 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 74, Bild 2 von 3 Honda EU2200IT A2 Rotor Replacement: Schritt 74, Bild 3 von 3
    • Remove the rotor.
    • Reassembly tip: When you replace the rotor, make sure the rotor aligns to the key on the shaft.
Abschluss
Arthur Shi
283.365 Reputation
587 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.636 Anleitungen geschrieben
1 Kommentar zur Anleitung
Thank you so much for such an awesome and detailed instructional presentation. Great job. Bill
Bill Dye - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 1,067
