Zum Hauptinhalt wechseln
Hoover Power Path Pro Advanced Power Switch Replacement
Was du brauchst
    1. Hoover Power Path Pro Advanced Power Switch Replacement, Power Switch: Schritt 1, Bild 1 von 1
      • Remove the lower brushroll from the bottom of the cleaner.
      Frag FixBot
      Kommentar hinzufügen
    2. Hoover Power Path Pro Advanced Power Switch Replacement: Schritt 2, Bild 1 von 1
      • Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
      Frag FixBot
    3. Hoover Power Path Pro Advanced Power Switch Replacement: Schritt 3, Bild 1 von 2 Hoover Power Path Pro Advanced Power Switch Replacement: Schritt 3, Bild 2 von 2
      • Pull the red handle to remove the front suction unit from the cleaner.
      Frag FixBot
    4. Hoover Power Path Pro Advanced Power Switch Replacement: Schritt 4, Bild 1 von 1
      • Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
      Frag FixBot
    5. Hoover Power Path Pro Advanced Power Switch Replacement: Schritt 5, Bild 1 von 2 Hoover Power Path Pro Advanced Power Switch Replacement: Schritt 5, Bild 2 von 2
      • Push down on the handle release button. Lift the edge of top cover connected to this button.
      • Repeat the above step for the "On/Off" button.
      • Pull entire top cover off.
      • Caution: when pulling the handle release button, make sure the top of the cleaner does not fall.
      Frag FixBot
    6. Hoover Power Path Pro Advanced Power Switch Replacement: Schritt 6, Bild 1 von 1
      • Remove the "On/Off" cap by pulling it upwards with caution.
      Frag FixBot
    7. Hoover Power Path Pro Advanced Power Switch Replacement: Schritt 7, Bild 1 von 1
      • Use a long #2 Philips head to remove the two screws from the arched grey piece.
      Frag FixBot
    8. Hoover Power Path Pro Advanced Power Switch Replacement: Schritt 8, Bild 1 von 2 Hoover Power Path Pro Advanced Power Switch Replacement: Schritt 8, Bild 2 von 2
      • Pull out the red power the red power switch.
      Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S16-G5, Banghart Winter 2018 Mitglied von Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Mitglieder
42 Anleitungen geschrieben
3 Kommentare zur Anleitung
What is the part number?
martahayner - Antwort Teilen
Thanks so much!!
debmccrimm - Antwort Teilen
you have to test the switch, mine tested ok which led me to the fuse between the motor and switch. It was bad, parts warehouse part # 440004065 does the trick.
frank - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 40
Insgesamt: 4,346
