Zum Hauptinhalt wechseln
Hover-1 H1 Power Button Replacement
Was du brauchst
    1. Hover-1 H1 Power Button  Replacement, Bottom Shell: Schritt 1, Bild 1 von 1
      • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      Frag FixBot
      Kommentar hinzufügen
    2. Hover-1 H1 Power Button  Replacement: Schritt 2, Bild 1 von 1
      • Puncture the two black stickers by using the tip of a screwdriver.
      • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      Frag FixBot
    3. Hover-1 H1 Power Button  Replacement: Schritt 3, Bild 1 von 2 Hover-1 H1 Power Button  Replacement: Schritt 3, Bild 2 von 2
      • Lift each side of the bottom shell by pulling up.
      • When lifting the shell, take care to not tear any cables from their connectors.
      Frag FixBot
    4. Hover-1 H1 Power Button  Replacement: Schritt 4, Bild 1 von 1
      • Unplug the battery by pulling gently on both sides of the orange connector.
      Frag FixBot
    1. Hover-1 H1 Power Button  Replacement, Power Button: Schritt 5, Bild 1 von 1
      • Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
      • Pull the cable through the center section of the hoverboard.
      • For reassembly, you will have to feed the cable back through the center section. This can be done using a rigid wire or cable.
      Frag FixBot
    2. Hover-1 H1 Power Button  Replacement: Schritt 6, Bild 1 von 2 Hover-1 H1 Power Button  Replacement: Schritt 6, Bild 2 von 2
      • Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
      Frag FixBot
    3. Hover-1 H1 Power Button  Replacement: Schritt 7, Bild 1 von 1
      • Pull the power button through the hole in the shell.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team S17-G6, White Fall 2018 Mitglied von Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 41
Insgesamt: 4,077
