Zum Hauptinhalt wechseln
How to Clean the Rollers in Your Polaroid Flip Camera
Was du brauchst
  1. How to Clean the Rollers in Your Polaroid Flip Camera, Before you begin: Schritt 1, Bild 1 von 3 How to Clean the Rollers in Your Polaroid Flip Camera, Before you begin: Schritt 1, Bild 2 von 3 How to Clean the Rollers in Your Polaroid Flip Camera, Before you begin: Schritt 1, Bild 3 von 3
    • Before you begin:
    • Unplug all cables from your camera.
    • Fully close the flash unit at the front of the camera to turn it off.
  2. How to Clean the Rollers in Your Polaroid Flip Camera, Open the film door: Schritt 2, Bild 1 von 3 How to Clean the Rollers in Your Polaroid Flip Camera, Open the film door: Schritt 2, Bild 2 von 3 How to Clean the Rollers in Your Polaroid Flip Camera, Open the film door: Schritt 2, Bild 3 von 3
    • Hold down the latch on the left side of the camera and open the film door.
  3. How to Clean the Rollers in Your Polaroid Flip Camera, Clean the rollers: Schritt 3, Bild 1 von 2 How to Clean the Rollers in Your Polaroid Flip Camera, Clean the rollers: Schritt 3, Bild 2 von 2
    • Lightly dampen a soft, clean cloth with water.
    • Use the cloth to gently clean the entire surface of both rollers, spinning them as necessary.
    • Allow the rollers to dry completely before using your camera again.
Abschluss
If cleaning the rollers doesn't solve your problem, they may be damaged. Follow this guide to replace the film door, which contains the rollers.
Spencer Day
149.339 Reputation
995 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
23.611 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 189
