Zum Hauptinhalt wechseln
How to Discharge a Capacitor in Large Machinery
Was du brauchst
  1. How to Discharge a Capacitor in Large Machinery, Create a capacitor discharge tool: Schritt 1, Bild 1 von 3 How to Discharge a Capacitor in Large Machinery, Create a capacitor discharge tool: Schritt 1, Bild 2 von 3 How to Discharge a Capacitor in Large Machinery, Create a capacitor discharge tool: Schritt 1, Bild 3 von 3
    • Inspect your capacitor and note the following:
    • The voltage rating of either your capacitor or the device
    • Where the terminals are located
    • Attach two wires to an incandescent lightbulb—making sure the bulb's voltage rating is greater or equal to the capacitor's.
  2. How to Discharge a Capacitor in Large Machinery, Discharge the capacitor: Schritt 2, Bild 1 von 2 How to Discharge a Capacitor in Large Machinery, Discharge the capacitor: Schritt 2, Bild 2 von 2
    • Don't touch the two wire leads together during this step, as this could short circuit the capacitor.
    • Lay one wire lead on the head of the terminal.
    • While holding the lead in place, lay the other wire lead on the opposite terminal to complete the circuit.
    • Hold this position for a few seconds or until the lightbulb completely darkens.
  3. How to Discharge a Capacitor in Large Machinery, Check with a multimeter: Schritt 3, Bild 1 von 1
    • If you have a multimeter, you can check to see if the capacitor is fully drained.
    • Set the meter to its DC voltage measuring mode and measure across the terminals.
    • Any value under 10 volts means your capacitor is sufficiently drained.
Abschluss
For other general electronics skills, click here.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Diaz-Kokaisl
125.070 Reputation
582 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 34
Letzte 30 Tage: 212
Insgesamt: 1,383
