Zum Hauptinhalt wechseln
How to Shorten Straps on a Tank Top by Hand
Was du brauchst
  1. How to Shorten Straps on a Tank Top by Hand, How to Shorten Straps on a Tank Top by Hand: Schritt 1, Bild 1 von 2 How to Shorten Straps on a Tank Top by Hand, How to Shorten Straps on a Tank Top by Hand: Schritt 1, Bild 2 von 2
    • Put on the top.
    • Hold and stretch the strap to the desired length.
    • Secure the desired length of the strap with a safety pin.
    • Be careful with the safety pin while securing the strap.
  2. How to Shorten Straps on a Tank Top by Hand: Schritt 2, Bild 1 von 1
    • Use a fabric pencil to mark both sides of the strap right above the safety pin.
  3. How to Shorten Straps on a Tank Top by Hand: Schritt 3, Bild 1 von 1
    • Remove the safety pin.
    • Use the ruler to measure the length between the two marks.
    • This length of the strap will be removed at the last step.
  4. How to Shorten Straps on a Tank Top by Hand: Schritt 4, Bild 1 von 2 How to Shorten Straps on a Tank Top by Hand: Schritt 4, Bild 2 von 2
    • Place the top down so the back is facing up.
    • Place one end of the ruler where the strap meets the back of the shirt.
    • Use the fabric pencil to mark the strap, using the measurement from the previous step.
  5. How to Shorten Straps on a Tank Top by Hand: Schritt 5, Bild 1 von 3 How to Shorten Straps on a Tank Top by Hand: Schritt 5, Bild 2 von 3 How to Shorten Straps on a Tank Top by Hand: Schritt 5, Bild 3 von 3
    • Draw a line with the fabric pencil on the seam below the strap on either side of the strap.
    • This is where you will sew the strap back in place.
  6. How to Shorten Straps on a Tank Top by Hand: Schritt 6, Bild 1 von 2 How to Shorten Straps on a Tank Top by Hand: Schritt 6, Bild 2 von 2
    • Use the seam ripper to rip the seams from the back of the strap where it meets the back of the shirt.
  7. How to Shorten Straps on a Tank Top by Hand: Schritt 7, Bild 1 von 3 How to Shorten Straps on a Tank Top by Hand: Schritt 7, Bild 2 von 3 How to Shorten Straps on a Tank Top by Hand: Schritt 7, Bild 3 von 3
    • Turn the top inside out.
    • Match the strap with the lines from Steps 4 and 5.
    • Pin the strap so it stays in place.
  8. How to Shorten Straps on a Tank Top by Hand: Schritt 8, Bild 1 von 3 How to Shorten Straps on a Tank Top by Hand: Schritt 8, Bild 2 von 3 How to Shorten Straps on a Tank Top by Hand: Schritt 8, Bild 3 von 3
    • Use a needle and a thread that has a similar color to the fabric to sew the strap to the seam of the top.
    • Use the white lines from the fabric pencil as a guide.
    • Pierce the needle through the fabric of the top and then pull the needle through the strap.
    • Continue the same process downwards until reaching the end of the seam of the top.
    • Tie a knot after pulling the string.
    • Cut the excess thread.
    • Repeat the step for the opposite side of the strap and the upper side of the strap.
  9. How to Shorten Straps on a Tank Top by Hand: Schritt 9, Bild 1 von 1
    • Put the top back on.
    • Make sure the top fits properly. If not, repeat the guide from Step 1.
  10. How to Shorten Straps on a Tank Top by Hand: Schritt 10, Bild 1 von 1
    • Use fabric scissors to cut the excess fabric.
    • Repeat all the steps for the other strap.
Ziellinie
Victoria Reyes
181 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 51
Letzte 30 Tage: 252
Insgesamt: 8,857
