Einleitung
Sometimes a scooter will move in a different direction than the user directs it. This guide will demonstrate how to align the steering column with the front wheel, and so that the scooter moves properly in the right direction.
Was du brauchst
Locate the collar clamp near the base of the steering column.
Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
Firmly grasp the steering column and turn the wheel by hand.
View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
17 weitere Personen haben diese Anleitung absolviert.
4 Kommentare zur Anleitung
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
