Zum Hauptinhalt wechseln
Huawei P10 Display Replacement
Was du brauchst
  1. Huawei P10 Display Replacement, Back Cover: Schritt 1, Bild 1 von 3 Huawei P10 Display Replacement, Back Cover: Schritt 1, Bild 2 von 3 Huawei P10 Display Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Display Replacement: Schritt 2, Bild 1 von 3 Huawei P10 Display Replacement: Schritt 2, Bild 2 von 3 Huawei P10 Display Replacement: Schritt 2, Bild 3 von 3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Display Replacement: Schritt 3, Bild 1 von 2 Huawei P10 Display Replacement: Schritt 3, Bild 2 von 2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Display Replacement, Main and display flex disconnect: Schritt 4, Bild 1 von 3 Huawei P10 Display Replacement, Main and display flex disconnect: Schritt 4, Bild 2 von 3 Huawei P10 Display Replacement, Main and display flex disconnect: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove the two Phillips #00 screws.
    • Use tweezers to remove both metal plates.
  5. Huawei P10 Display Replacement: Schritt 5, Bild 1 von 3 Huawei P10 Display Replacement: Schritt 5, Bild 2 von 3 Huawei P10 Display Replacement: Schritt 5, Bild 3 von 3
    • Use a spudger to disconnect the interconnect, the battery and the display flex cable.
  6. Huawei P10 Display Replacement, Charging Board: Schritt 6, Bild 1 von 2 Huawei P10 Display Replacement, Charging Board: Schritt 6, Bild 2 von 2
    • Remove the four Phillips #00 screws.
    • Use Tweezers to remove the metal plate.
  7. Huawei P10 Display Replacement: Schritt 7, Bild 1 von 2 Huawei P10 Display Replacement: Schritt 7, Bild 2 von 2
    • Use a spudger to disconnect the main flex cable.
    • Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
  8. Huawei P10 Display Replacement: Schritt 8, Bild 1 von 2 Huawei P10 Display Replacement: Schritt 8, Bild 2 von 2
    • Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
  9. Huawei P10 Display Replacement: Schritt 9, Bild 1 von 2 Huawei P10 Display Replacement: Schritt 9, Bild 2 von 2
    • Do not damage any components sitting on the charging board while removing it.
    • Use a spudger to pry out the charging board.
    • Remove the charging board.
  10. Huawei P10 Display Replacement, Loudspeaker: Schritt 10, Bild 1 von 2 Huawei P10 Display Replacement, Loudspeaker: Schritt 10, Bild 2 von 2
    • Only insert the spudger as deep as 1/16 of an inch to avoid damage.
    • Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can use an iOpener to loosen it.
    • Remove the loudspeaker.
    • When reassembling your phone, apply new adhesive where it's necessary.
  11. Huawei P10 Display Replacement, Display: Schritt 11, Bild 1 von 2 Huawei P10 Display Replacement, Display: Schritt 11, Bild 2 von 2
    • Remove the antenna cable if you haven't already.
    • Use tweezers to remove the interconnect cable.
    • Use an iOpener to loosen the adhesive beneath the display. Especially take care of the upper and lower part of the display.
  12. Huawei P10 Display Replacement: Schritt 12, Bild 1 von 3 Huawei P10 Display Replacement: Schritt 12, Bild 2 von 3 Huawei P10 Display Replacement: Schritt 12, Bild 3 von 3
    • Insert the tip of an opening pick between the display and the midframe on the bottom of the phone, near the home button.
    • Slide the opening pick along the bottom edge, to cut the adhesive.
    • Slide the opening pick to the bottom right corner and leave it there.
    • Insert another opening pick under the screen on the bottom left corner.
  13. Huawei P10 Display Replacement: Schritt 13, Bild 1 von 3 Huawei P10 Display Replacement: Schritt 13, Bild 2 von 3 Huawei P10 Display Replacement: Schritt 13, Bild 3 von 3
    • Slide the opening pick under the screen around all edges of the phone.
    • If the adhesive gets tough to pry it is likely too cold. Use your iOpener or heat gun to reheat it.
  14. Huawei P10 Display Replacement: Schritt 14, Bild 1 von 2 Huawei P10 Display Replacement: Schritt 14, Bild 2 von 2
    • Carefully pull the display assembly away from the frame.
    • Remove the display assembly.
Abschluss
23 weitere Personen haben diese Anleitung absolviert.
Dominik Schnabelrauch
249.310 Reputation
682 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
23.918 Anleitungen geschrieben
4 Kommentare zur Anleitung
Any advice which adhesive to use? I’ve seen a russian replacement video, it looked like the guy was using some kind of silicone.
Tom My - Antwort
I used B-7000 glue. It enables you to release the screen when a second replacement is needed.
teunkeusters -
Assuming I purchase a screen off of ebay, and replace it using this method, will the touch id still work?
Simon Fisher - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 49
Letzte 30 Tage: 131
Insgesamt: 28,302
