Einleitung
Use this guide to replace the vibration motor in your Huawei P10 smartphone. When reassembling your phone apply new adhesive where it is necessary.
Was du brauchst
Switch off your phone.
Remove the two Pentalobe P2 screws at the bottom.
Remove the SIM card tray.
Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
Carefully pry the display with its parts out of the case.
After you pried out the bottom end, use the opening tool to open the clamps on both sides.
Swing open the phone backwards.
Use a spudger to disconnect the power- and volume button flex cable.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the Phillips #00 screw.
Use tweezers to remove the metal plate.
Use a spudger to disconnect the battery flex cable.
Remove the four Phillips #00 screws.
Use Tweezers to remove the metal plate.
Use a spudger to disconnect the main flex cable.
Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
Use tweezers to remove the vibration motor.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
