Zum Hauptinhalt wechseln
Huawei P8 Lite Battery Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
Einführungsvideo
  1. Huawei P8 Lite Battery Replacement, Remove  Back Cover and Loudspeaker: Schritt 1, Bild 1 von 2 Huawei P8 Lite Battery Replacement, Remove  Back Cover and Loudspeaker: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Spudger
    $2.99
    Kaufen
    • Use the Spudger tool to get access to the loudspeaker. Locate where the headphone jack is, then move about one-inch to the right and begin to gently pry the back-cover off the phone with the flat end of the Spudger tool. Make sure to pry apart the entire perimeter of the back-cover to prevent bending/cracking of the plastic.
    • Tools used: Spudger tool (used as a wedge to pry off the back-cover and loudspeaker.)
  2. Huawei P8 Lite Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove three silver Phillips 000 screws.
    • Remove four T5 Torx screws.
  3. Huawei P8 Lite Battery Replacement: Schritt 3, Bild 1 von 2 Huawei P8 Lite Battery Replacement: Schritt 3, Bild 2 von 2
    Spudger
    $2.99
    Kaufen
    • Gently, use the flat end of the Spudger tool, or a metal opening tool to lift and remove the loudspeaker from the phone. The loudspeaker is the entire portion of the phone where the screws were extracted.
  4. Huawei P8 Lite Battery Replacement, Replace Battery: Schritt 4, Bild 1 von 1
    • Locate adhesive strip underneath the battery and grip with your thumb and forefinger. Slowly pull on the adhesive strip until it's off to release adhesive securing battery.
  5. Huawei P8 Lite Battery Replacement: Schritt 5, Bild 1 von 1
    Spudger
    $2.99
    Kaufen
    • Insert the Spudger tool underneath the battery multiple times to separate the adhesive securing the battery. Be careful not to bend the battery and lift it from the phone frame.
    • Replace the adhesive and insert the replacement battery into the slot.
Abschluss
To reassemble your device, follow these steps in reverse order.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Metro State, Team 1-2, Carpenter Spring 2016 Mitglied von Metro State, Team 1-2, Carpenter Spring 2016
MSU-CARPENTER-S16S1G2
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 9,148
