Einleitung
Use this guide to replace the charging board in your Huawei P9 smartphone.
Was du brauchst
First switch off your phone and remove the SIM card tray.
Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
Undo the three Phillips #00 screws.
Disconnect the loudspeaker flex connector.
Carefully remove the metal bracket.
Disconnect the motherboard flex cable and the antenna cable.
Unplug the headphone jack connector.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
