Zum Hauptinhalt wechseln
Infant Optics DXR-8 Battery Replacement
    1. Infant Optics DXR-8 Battery  Replacement, Battery: Schritt 1, Bild 1 von 3 Infant Optics DXR-8 Battery  Replacement, Battery: Schritt 1, Bild 2 von 3 Infant Optics DXR-8 Battery  Replacement, Battery: Schritt 1, Bild 3 von 3
      • Begin by holding the Monitor so that the backside is flipped up. This is where your battery is located.
      • Slide the battery panel downwards to detach it completely. The battery should be completely visible.
      Frag FixBot
      Kommentar hinzufügen
    2. Infant Optics DXR-8 Battery  Replacement: Schritt 2, Bild 1 von 3 Infant Optics DXR-8 Battery  Replacement: Schritt 2, Bild 2 von 3 Infant Optics DXR-8 Battery  Replacement: Schritt 2, Bild 3 von 3
      • Now that your battery is exposed, begin to take the battery out. The only thing keeping the battery in the battery port should be the plug.
      • Now unplug the battery from the battery port. The plug is small so be careful locating it.
      • The battery and plug should be completely out of the battery port.
      Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 13-4, Banghart Winter 2017 Mitglied von Cal Poly, Team 13-4, Banghart Winter 2017
CPSU-BANGHART-W17S13G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 57
Insgesamt: 12,551
