Zum Hauptinhalt wechseln
Instant Pot 60 EPC Circuit Board Replacement
Was du brauchst
  1. Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: Schritt 1, Bild 1 von 3 Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: Schritt 1, Bild 2 von 3 Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: Schritt 1, Bild 3 von 3
    • Ensure the device is unplugged and cool before beginning.
    • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
    • Remove the single Torx screw.
  2. Instant Pot 60 EPC Circuit Board Replacement: Schritt 2, Bild 1 von 2 Instant Pot 60 EPC Circuit Board Replacement: Schritt 2, Bild 2 von 2
    • Turn the bottom face counterclockwise and remove it.
  3. Instant Pot 60 EPC Circuit Board Replacement: Schritt 3, Bild 1 von 3 Instant Pot 60 EPC Circuit Board Replacement: Schritt 3, Bild 2 von 3 Instant Pot 60 EPC Circuit Board Replacement: Schritt 3, Bild 3 von 3
    • In order to reach the circuit board you'll need to remove the secondary frame surrounding it.
    • Remove the three Phillips screws securing the frame.
    • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
  4. Instant Pot 60 EPC Circuit Board Replacement: Schritt 4, Bild 1 von 3 Instant Pot 60 EPC Circuit Board Replacement: Schritt 4, Bild 2 von 3 Instant Pot 60 EPC Circuit Board Replacement: Schritt 4, Bild 3 von 3
    • Depress the latch securing the red connector and disconnect it.
    • Repeat the previous bullet for the white and black connectors.
    • It can be helpful to gently rock them back and forth while pulling up.
  5. Instant Pot 60 EPC Circuit Board Replacement: Schritt 5, Bild 1 von 2 Instant Pot 60 EPC Circuit Board Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips screwdriver to remove the two screws holding each of the two leads in place.
  6. Instant Pot 60 EPC Circuit Board Replacement: Schritt 6, Bild 1 von 2 Instant Pot 60 EPC Circuit Board Replacement: Schritt 6, Bild 2 von 2
    • Gently walk the 8x1 pin connector out of its socket.
    • It may be helpful to also rock the plug side to side while pulling up.
  7. Instant Pot 60 EPC Circuit Board Replacement: Schritt 7, Bild 1 von 3 Instant Pot 60 EPC Circuit Board Replacement: Schritt 7, Bild 2 von 3 Instant Pot 60 EPC Circuit Board Replacement: Schritt 7, Bild 3 von 3
    • Slide the blue sheathing up to expose the small hole in the lead.
    • Place a SIM card punch into the hole to unsecure the leads and pull them up. If a SIM card punch is not available, then a paperclip or earring should suffice.
    • Repeat for the other two leads.
  8. Instant Pot 60 EPC Circuit Board Replacement: Schritt 8, Bild 1 von 2 Instant Pot 60 EPC Circuit Board Replacement: Schritt 8, Bild 2 von 2
    • Pull the board up slightly to unclip it from its stand and lift from the body to remove the circuit board.
  9. Instant Pot 60 EPC Circuit Board Replacement: Schritt 9, Bild 1 von 1
    • Instant Pot does not provide a new sensor with the device, so it will have to be purchased from a secondary source.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
3 weitere Personen haben diese Anleitung absolviert.
Bela Hernandez
926 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 87
