Zum Hauptinhalt wechseln
JBL Flip disassembly
Was du brauchst
    1. JBL Flip disassembly, JBL Flip disassembly: Schritt 1, Bild 1 von 3 JBL Flip disassembly, JBL Flip disassembly: Schritt 1, Bild 2 von 3 JBL Flip disassembly, JBL Flip disassembly: Schritt 1, Bild 3 von 3
      • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
      • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
      Frag FixBot
      Kommentar hinzufügen
    2. JBL Flip disassembly: Schritt 2, Bild 1 von 3 JBL Flip disassembly: Schritt 2, Bild 2 von 3 JBL Flip disassembly: Schritt 2, Bild 3 von 3
      • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
      Frag FixBot
    3. JBL Flip disassembly: Schritt 3, Bild 1 von 3 JBL Flip disassembly: Schritt 3, Bild 2 von 3 JBL Flip disassembly: Schritt 3, Bild 3 von 3
      • Remove outermost white casing by gently lifting up on one side.
      • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
      • Gently lift up and remove the silver casing.
      Frag FixBot
    4. JBL Flip disassembly: Schritt 4, Bild 1 von 1
      • Remove last white back plate to expose the back of the speaker cover.
      Frag FixBot
    5. JBL Flip disassembly: Schritt 5, Bild 1 von 3 JBL Flip disassembly: Schritt 5, Bild 2 von 3 JBL Flip disassembly: Schritt 5, Bild 3 von 3
      • Pry the four tabs on each side of the speaker cover (8 tabs total).
      • Pry the two tabs on each end to remove the cover (4 tabs total).
      • Slide speaker out of metal speaker cover.
      Frag FixBot
    6. JBL Flip disassembly: Schritt 6, Bild 1 von 3 JBL Flip disassembly: Schritt 6, Bild 2 von 3 JBL Flip disassembly: Schritt 6, Bild 3 von 3
      • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
      • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
      • Open the speaker.
      Frag FixBot
Abschluss
12 weitere Personen haben diese Anleitung absolviert.
Dillon
1.622 Reputation
5 Anleitungen geschrieben
Colorado Springs, Team 9-5, Panko Spring 2015 Mitglied von Colorado Springs, Team 9-5, Panko Spring 2015
UCCS-PANKO-S15S9G5
3 Mitglieder
20 Anleitungen geschrieben
4 Kommentare zur Anleitung
How do i take apart jbl flip 3
Ricky Tomas - Antwort Teilen
My jbl flip 3 Bluetooth button does not function.How do I fix the problem?
Francis
fwathika - Antwort Teilen
The charging PCB on my Flip3 is damaged and needs to be replaced. Any chance of purchasing the charging/interface module, fully populated?
I live in South Africa, and cannot find it here!
Paul M
Paul Moulang - Antwort Teilen
The charging PCB on my JBL Flip3 is also damaged and needs to be replaced. Any chance of purchasing the charging/interface module?
I live in Pune - Maharashtra in India and cannot find a good reliable service station for JBL speakers here!
Suresh Karve
Suresh Karve - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 32
Letzte 30 Tage: 129
Insgesamt: 23,857
