Einleitung
If your computer continuously gives off a burning odor or it keeps crashing after bugs have supposedly been fixed, chances are you need to replace your Display driver. This guide will show you exactly how to do that through simple, easy to follow steps with pictures to help you along. The only tool you will be needing is a Phillips #1 Screwdriver for the four 8.5mm screws to complete this guide.
Was du brauchst
Take off the clear backing of the computer and set it aside.
The Display board is located in the top right corner of the case.
Always disconnect the battery before performing repairs.
Remove the power cable (Circled in red) from the board.
Eine weitere Person hat diese Anleitung absolviert.
