Einleitung
Use this guide to replace a key or or multiple keys in your Kano Computer Kit Complete keyboard. The keyboard is a piece of hardware that allows you to type and enter commands to your computer. A key may need to be replaced when a key breaks or if a key is no longer working properly. In some cases, your keyboard key may not work when pressed. This guide only requires a 1mm flat head screwdriver. Be careful when removing keys as some could be a choking hazard. Any further questions can be answered by going to Kano’s Help site.
Was du brauchst
Use your 1mm flathead to pop the key off. Make sure the flathead is all the way under the key so you can get good leverage.
To reassemble your device, press the key back into place.
2 weitere Personen haben diese Anleitung absolviert.
