Einleitung
This guide shows how to remove and replace the vacuum motor/turbine for the Karcher Rotary Floor Cleaner 17833080 2017.
Was du brauchst
Press the yellow button near each wheel base to release the wheels.
Remove both wheels from their sockets.
Use a T20 driver to remove the three screws securing the pump cover.
Squeeze the left plug by the edges and pull it out of its socket.
Use a T20 driver to remove the two screws securing the vacuum cover.
Disconnect the two motor wires by pulling the plugs off their spade sockets.
Use a T20 driver to remove the five screws securing the vacuum housing.
Lift the vacuum housing to remove it.
Reassembly tip: During reassembly, be sure to thread the motor wires through cutout on the side of the vacuum housing.
Reassembly tip: Be sure to properly align the vacuum housing to the rubber motor seal.
Peel the lower rubber seal from the motor and transfer it to the replacement part.
Peel the upper rubber seal from the motor and transfer it to the replacement part.
The upper seal is keyed to the motor. Be sure to properly align it during assembly.
Eine weitere Person hat diese Anleitung absolviert.
