Einleitung
Follow this guide to remove and replace the power switch module from the Karcher Vacuum Universal 14286230 2014.
Was du brauchst
Release the two latches locking the top assembly in place.
Lift and remove the top plastic cover from the motor assembly.
The switch module should line up with the yellow plastic switch plunger.
The two plastic moulded discs line up using this black tab.
Unplug the wires from the switch. These are standard spade terminals that can be pulled apart.
Remove the switch.
Eine weitere Person hat diese Anleitung absolviert.
