Einleitung
This Kocaso M750B guide will show you how to replace the display assembly of your tablet. If you dropped your device and cracked the display, you may need to replace the screen to continue using it.
This repair requires soldering soldering and desoldering connections. For safety purposes, there are guidelines on how to solder, visit this page for more information.
Before you begin this repair, power off your tablet and unplug it from the charging adaptor.
Was du brauchst
Remove three 1.2 mm screws from the motherboard using a Phillips #000 screwdriver.
