Zum Hauptinhalt wechseln
LCD Screen Replacement
Was du brauchst
    1. LCD Screen  Replacement, Battery Door: Schritt 1, Bild 1 von 1
      • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
      Frag FixBot
      Kommentar hinzufügen
    2. LCD Screen  Replacement: Schritt 2, Bild 1 von 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
      Frag FixBot
    3. LCD Screen  Replacement: Schritt 3, Bild 1 von 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
      Frag FixBot
    4. LCD Screen  Replacement: Schritt 4, Bild 1 von 2 LCD Screen  Replacement: Schritt 4, Bild 2 von 2
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
      • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
      Frag FixBot
    5. LCD Screen  Replacement: Schritt 5, Bild 1 von 1
      • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
      Frag FixBot
    6. LCD Screen  Replacement: Schritt 6, Bild 1 von 3 LCD Screen  Replacement: Schritt 6, Bild 2 von 3 LCD Screen  Replacement: Schritt 6, Bild 3 von 3
      • Use the plastic opening tool to pry the back and front casings of the camera apart.
      • Once pried apart use your hands to pull off the back plate of the camera.
      • You will need to apply a little bit of force to remove the back plate.
      Frag FixBot
    7. LCD Screen  Replacement: Schritt 7, Bild 1 von 3 LCD Screen  Replacement: Schritt 7, Bild 2 von 3 LCD Screen  Replacement: Schritt 7, Bild 3 von 3
      • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
      Frag FixBot
    1. LCD Screen  Replacement, LCD Screen: Schritt 8, Bild 1 von 3 LCD Screen  Replacement, LCD Screen: Schritt 8, Bild 2 von 3 LCD Screen  Replacement, LCD Screen: Schritt 8, Bild 3 von 3
      • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 3-2, Sullivan Spring 2016 Mitglied von USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 985
