Zum Hauptinhalt wechseln
LG BP220 Disc Drive Replacement
Was du brauchst
    1. LG BP220 Disc Drive Replacement, Disc Drive: Schritt 1, Bild 1 von 2 LG BP220 Disc Drive Replacement, Disc Drive: Schritt 1, Bild 2 von 2
      • Ensure the device is unplugged to prevent shocks.
      • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
      • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
      Frag FixBot
      Kommentar hinzufügen
    2. LG BP220 Disc Drive Replacement: Schritt 2, Bild 1 von 1
      • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
      Frag FixBot
    3. LG BP220 Disc Drive Replacement: Schritt 3, Bild 1 von 3 LG BP220 Disc Drive Replacement: Schritt 3, Bild 2 von 3 LG BP220 Disc Drive Replacement: Schritt 3, Bild 3 von 3
      • Unhinge the tabs that attach the front panel to the unit:
      • Two tabs on the disc drive
      • Two tabs on the left and right side of the player
      • Be careful when handling these tabs. They are very fragile and can be easily broken.
      • Three tabs on the underside of the player
      • Pull panel away from case.
      • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
      Frag FixBot
    4. LG BP220 Disc Drive Replacement: Schritt 4, Bild 1 von 2 LG BP220 Disc Drive Replacement: Schritt 4, Bild 2 von 2
      • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
      • With the front side facing you lift the front of disc drive and pull out to remove.
      Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
UW Tacoma, Team 1-1, Rose Winter 2015 Mitglied von UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 64
Insgesamt: 9,592
