Zum Hauptinhalt wechseln
LG Optimus T Button Replacement
Was du brauchst
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using a prying device, such as a Spudger, remove the phone's back cover. At the top of the phone, there's an indentation to put the Spudger into to pop the case off.
    Frag FixBot
    Kommentar hinzufügen
  1. LG Optimus T Button Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery. There's an indentation to the left of the camera lens to pull up on the battery with your finger.
    Frag FixBot
  2. LG Optimus T Button Replacement: Schritt 3, Bild 1 von 1
    • Use a J0 screwdriver to remove the six 4.5 mm screws.
    Frag FixBot
  3. LG Optimus T Button Replacement: Schritt 4, Bild 1 von 2 LG Optimus T Button Replacement: Schritt 4, Bild 2 von 2
    • Remove interior case. Insert the spudger into the indentations at the top or bottom of the phone to pry off the interior case.
    • You might have difficulty popping the case off. You may use the metal spudger if the plastic one fails. Be cautious when using it, as the metal spudger may damage your phone.
    Frag FixBot
  4. LG Optimus T Button Replacement: Schritt 5, Bild 1 von 3 LG Optimus T Button Replacement: Schritt 5, Bild 2 von 3 LG Optimus T Button Replacement: Schritt 5, Bild 3 von 3
    • Remove power button found on top of the phone.
    • Remove the volume button found on the side of the phone.
    • There is an indentation that has been marked near the edge that part of the volume button inserts in to. You will use this when reassembling your phone.
    • When reassembling your phone, place buttons on the metal nodes that have been marked.
    Frag FixBot
  5. LG Optimus T Button Replacement: Schritt 6, Bild 1 von 1
    • Pull up on connector tab.
    Frag FixBot
  6. LG Optimus T Button Replacement: Schritt 7, Bild 1 von 2 LG Optimus T Button Replacement: Schritt 7, Bild 2 von 2
    • Remove SD card mount. Insert a plastic opening tool on the right side to pop off.
    Frag FixBot
  7. LG Optimus T Button Replacement: Schritt 8, Bild 1 von 2 LG Optimus T Button Replacement: Schritt 8, Bild 2 von 2
    • There are 4 retaining points to insert a plastic opening tool into and pop off panel.
    Frag FixBot
  8. LG Optimus T Button Replacement: Schritt 9, Bild 1 von 1
    • Remove 2 black J0 Phillip's head 1.8 mm screws from charging port.
    • Charging port and motherboard are connected.
    • Remove motherboard.
    Frag FixBot
  9. LG Optimus T Button Replacement: Schritt 10, Bild 1 von 2 LG Optimus T Button Replacement: Schritt 10, Bild 2 von 2
    • Pop off home buttons.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ohio State, Team 1-3, Wilder Spring 2017 Mitglied von Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 32
Insgesamt: 438
