Zum Hauptinhalt wechseln
LG Power Screen Replacement
Was du brauchst
  1. LG Power Screen Replacement, Battery: Schritt 1, Bild 1 von 2 LG Power Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
    • A metal spudger can easily damage your device. A plastic opening tool is always the only option.
    Frag FixBot
    Kommentar hinzufügen
  2. LG Power Screen Replacement: Schritt 2, Bild 1 von 2 LG Power Screen Replacement: Schritt 2, Bild 2 von 2
    • Carefully pop the back panel off and place it to the side.
    Frag FixBot
  3. LG Power Screen Replacement: Schritt 3, Bild 1 von 2 LG Power Screen Replacement: Schritt 3, Bild 2 von 2
    • Use the thumb tab to remove the battery.
    Frag FixBot
  4. LG Power Screen Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Remove the eight 4mm screws along the side of the mid panel using the Phillips #000 screwdriver head.
    Frag FixBot
  5. LG Power Screen Replacement: Schritt 5, Bild 1 von 2 LG Power Screen Replacement: Schritt 5, Bild 2 von 2
    • Slide a plastic opening tool between the mid and front panel to remove the middle panel.
    • Place the mid panel to the side.
    Frag FixBot
  6. LG Power Screen Replacement: Schritt 6, Bild 1 von 3 LG Power Screen Replacement: Schritt 6, Bild 2 von 3 LG Power Screen Replacement: Schritt 6, Bild 3 von 3
    • Detach the motherboard and touchscreen from each other by using a plastic opening tool.
    • The motherboard will then be free from the phone.
    Frag FixBot
  7. LG Power Screen Replacement, Screen: Schritt 7, Bild 1 von 3 LG Power Screen Replacement, Screen: Schritt 7, Bild 2 von 3 LG Power Screen Replacement, Screen: Schritt 7, Bild 3 von 3
    • After removing the motherboard, slide a thin plastic opening tool between the screen and the frame.
    • This step may take awhile, because of the glue keeping the frame and screen together.
    Frag FixBot
Abschluss
12 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 4-6, Lacy Spring 2016 Mitglied von USF Tampa, Team 4-6, Lacy Spring 2016
USFT-LACY-S16S4G6
4 Mitglieder
15 Anleitungen geschrieben
9 Kommentare zur Anleitung
do i need a replacement screen?
jj - Antwort Teilen
My screen is shattered otherwise the phone works fine..touch works and screen under glass is good. I want to replace the screen myself but my question is are the screen and digitizer fused (one piece) or can I just replace the glass screen? For an LG power x
Nikki - Antwort Teilen
Did you ever figure out if there the same or separate. I'm needing to do the same.
sarahelizabeth0526 - Antwort Teilen
Where do I buy the glass panel?
Liam McBride - Antwort Teilen
i got the glass screen at amazonbot most digitisers have a ribbon wire to connecttheres doesnt..not sure if its just held on with 2 face tape??
Peter Maggiop - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 38
Insgesamt: 26,650
