Zum Hauptinhalt wechseln
LG Spectrum Sim/SD Port Replacement
Was du brauchst
  1. LG Spectrum Sim/SD Port Replacement, Battery: Schritt 1, Bild 1 von 2 LG Spectrum Sim/SD Port Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
    Frag FixBot
    Kommentar hinzufügen
  2. LG Spectrum Sim/SD Port Replacement: Schritt 2, Bild 1 von 1
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
    Frag FixBot
  3. LG Spectrum Sim/SD Port Replacement, Sim/SD Port: Schritt 3, Bild 1 von 2 LG Spectrum Sim/SD Port Replacement, Sim/SD Port: Schritt 3, Bild 2 von 2
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnetic mat to keep the screws in one place.
    Frag FixBot
  4. LG Spectrum Sim/SD Port Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
    Frag FixBot
  5. LG Spectrum Sim/SD Port Replacement: Schritt 5, Bild 1 von 1
    • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
    Frag FixBot
  6. LG Spectrum Sim/SD Port Replacement: Schritt 6, Bild 1 von 1
    • Hook the plastic opening tool underneath the plate and gently lift it up.
    Frag FixBot
  7. LG Spectrum Sim/SD Port Replacement: Schritt 7, Bild 1 von 1
    • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
    Frag FixBot
Abschluss
USF Tampa, Team 1-4, Sullivan Spring 2016 Mitglied von USF Tampa, Team 1-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G4
3 Mitglieder
15 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 428
