Zum Hauptinhalt wechseln
LG Tribute Front Facing Camera Replacement
Was du brauchst
  1. LG Tribute Front Facing Camera  Replacement, Battery: Schritt 1, Bild 1 von 2 LG Tribute Front Facing Camera  Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool to pry off the back cover.
    Frag FixBot
    Kommentar hinzufügen
  2. LG Tribute Front Facing Camera  Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
    Frag FixBot
  3. LG Tribute Front Facing Camera  Replacement, Mid-panel: Schritt 3, Bild 1 von 2 LG Tribute Front Facing Camera  Replacement, Mid-panel: Schritt 3, Bild 2 von 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    Frag FixBot
  4. LG Tribute Front Facing Camera  Replacement: Schritt 4, Bild 1 von 2 LG Tribute Front Facing Camera  Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
    Frag FixBot
  5. LG Tribute Front Facing Camera  Replacement, Front Facing Camera: Schritt 5, Bild 1 von 2 LG Tribute Front Facing Camera  Replacement, Front Facing Camera: Schritt 5, Bild 2 von 2
    • Use the plastic opening tool to carefully pry the front-facing camera from the motherboard.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 1,313
